CC and other module programming for EU(IT) Kuga MY2017
lskg
Vehicle: Ford Kuga ST-Line 1500 TDCI 120cv 2017
Post by lskg » Mon Feb 05, 2018 8:45 pm
Hi to all and many thanks to FORScan guys for their amazing work.
I'm a newbie to FORScan, but i use it without problem (good usb obd2 module, 2.3.12 version and now 2.3.13 version with extended license, vbf file, ecc).
I've successfully made some mod on my car APIM to activate Clima Control and ST logo splash screen on Sync 3.
I can read without problem at CC of my car, but what i don't understand is if CC programming in FORScan is fully compatible with my car; I see many parameters with their default values, but i don't know if this parameters and their default/alternative values are correctly mapped for my car.
In another thread and another forum i've read that for my car the only things avalaible for change with FORScan are Clima Control and ST logo (APIM), but i think that if i see the CC programming page in FORScan then i can use it to mod the CC.
Some explanation? (and sorry for my poor english).
And sorry for cross posting (i write all the same in pinned topic "How to program Central Configuration using FORScan")
Thank you.
lskg
Re: CC and other module programming for EU(IT) Kuga MY2017
Post by lskg » Wed Feb 07, 2018 1:16 pm
Hi to all,
nobody has some explanations to give?
lskg
Post by lskg » Fri Feb 16, 2018 12:58 pm
Hi to all.
I did some tests and I'll continue to do.
I'll share my esperiences here for those interested.
BdyCM CC (Main) - Automatic locking by speed
Never seen before in other forums for my car, I have successfully activated this option, set to "Automatic locking".
Automatic locking occurs at 11-12 Km/h.
Now the procedure at http://www.youtube.com/watch?v=X9VXONMv7OM is working and I can activate or disactivate the option.
APIM - Climate button on Sync 3 screen
7D0-01-02: xxxx x3xx xxxx
APIM - See set climate temperature on Sync 3 screen
7D0-04-01: xxxx xxx0 xxxx
APIM - Set Ford ST logo as boot/shutdown screen on Sync 3 screen
7D0-02-01: xxxx 0Bxx xxxx
This is, for me, the most enjoyable logo.
There is no way, apparently, to combine/force this logo with Ford GT Theme.
APIM - Set Ford GT Theme on Sync 3 screen
7D0-03-01: xxxx 04xx xxxx
This is, for me, the most enjoyable and readable theme.
There is no way, apparently, to combine/force this theme with Ford ST Logo.
APIM - Set Ford GT logo as boot/shutdown screen on Sync 3 screen
7D0-02-01: xxxx 0Dxx xxxx
If there is someone that would contribute with other working options/parameters with the same car, then I'll collect them in this thread.
Regards.
Felix8
Vehicle: Ford S-max 1.5 ecoboost
Post by Felix8 » Fri Feb 16, 2018 5:28 pm
Hi
Sounds cool with tha apim, can you post a pic of it?
lskg
Post by lskg » Sat Feb 17, 2018 3:33 pm
Here are the pic.
Clima control
Clima control.jpg (67.24 KiB) Viewed 10183 times
See temp setting
See temp setting.jpg (61.01 KiB) Viewed 10183 times
ST logo
ST logo.jpg (63.37 KiB) Viewed 10183 times
Anyway, these are already well known modification.
Umberto
Vehicle: Ford Mustang
Post by Umberto » Tue Feb 27, 2018 8:25 am
I had information on this topic on http://www.idaf.it.
I was interested in auto lock.
I had seen the video, but it did not work on mine.
The operations shown do not involve Forscan.
Mine is a European version 2017 (Italy). What version did you manage to make the procedure shown in the video?
lskg
Post by lskg » Tue Feb 27, 2018 10:10 am
lskg wrote: BdyCM CC (Main) - Automatic locking by speed
The operation involve Forscan!
Title of the topic is "CC and other module programming for EU(IT) Kuga MY2017"!
As i've clearly written, the Ford procedure become working after programming BdyCM CC (Main): "Automatic locking by speed" parameter set to "Automatic locking".
It seems to me that it is sufficiently clear...
lskg
Post by lskg » Wed Feb 28, 2018 10:03 am
Hi to all.
I've updated the list with the parameter to force GT logo with the GT theme.
Belerofonte
Vehicle: Ford Kuga ST Line
Post by Belerofonte » Fri Mar 02, 2018 6:33 pm
I've recently bought my Kuga 2017 and I'll try to do this procedures, thanks for all!
lskg
Post by lskg » Sat Mar 03, 2018 2:31 pm
Wonderful!
Let me know if it is okay.
Regards.
