2017 SuperDuty Problem
wes57_02
Vehicle: F350, 6.7 L Powerstroke, 2017
Post by wes57_02 »
I completed the following changes on my truck this afternoon:
Double Horn Honk Disable............BdyCM as built......726-41-02.....xxx1 xxxx xxxx.....xxx0 xxxx xxxx
Fog Lights with High Beam LED......BdyCM as built......726-27-01.....xxxx xxx1 xxxx.....xxxx xxx0 xxxx
Show Temps on Gauges...............IPC....................720-07-01.....xxxx xEA xxxx......xxxx x**x xxxx
Heated and Cooled Seats Icons......APIM..................7D0-01-01.....xxxx xxxx x4xx.....xxxx xxxx x*xx
Secure Idle (Police Mode).............BdyCM as built.....726-42-01......x0xx xxxx xxxx.....x1xx xxxx xxxx
Add DPF Filter % to screen............IPC...................720-07-02......x7xx xxxx ..........xFxx xxxx
For the DPF Filter % my original value was a 7 therefore I replaced it with the F per the notes section on the spreadsheet below:
https://docs.google.com/spreadsheets/d/ ... s/htmlview
I completed the key cycle, disconnected from the module after each program, and verified that the each program worked afterwards. The problem I am having is that my TPMS is not working now. Just shows dashes instead of the actual tire pressure. Has anyone had this problem or could refer me somewhere to look?
Thank you very much!
wes57_02
Re: 2017 SuperDuty Problem
Post by wes57_02 »
RESOLVED!
2ndgnv82
Vehicle: 2017 f-350 6.7 diesel
Post by 2ndgnv82 »
What is supposed to go where the x's are
wes57_02
Post by wes57_02 »
Nothing, the "x" value is used as place holders that you ignore.
spectre127
Vehicle: 2017 Ford F250 6.7 lariat
Post by spectre127 »
What did you do to resolve this? Did the same changes as you did and having the same problem.
wes57_02
Post by wes57_02 »
Just drive it, it will fix itself.
MuleSkinner
Vehicle: 2017 F250 Super duty 6.7l
Post by MuleSkinner »
wes57_02 wrote:
Fri Dec 22, 2017 5:21 pm
RESOLVED!
So? How was it resolved? NM - Read the rest of the thread :)
Demonrekon
Vehicle: f250 diesel 6.7L 250 2019
Post by Demonrekon »
just go drive it when programming it resets the saved data from previous drive cycle. which is what displays on the dash at first startup unless a tire is flat.
