s550 Mustang codes
MalcolmV8
Vehicle: ford mustang 5.0 auto 2015
s550 Mustang codes
Post by MalcolmV8 » Sat Dec 02, 2017 8:33 pm
I've searched around quite a bit and the most comprhensive list I've found was this spreadsheet
https://docs.google.com/spreadsheets/d/ ... edit#gid=0
The link was found on this forum thread
http://www.mustang6g.com/forums/showthread.php?t=61773
I tried a few of them and they worked. Some did not such as the Sync/MFT Startup Animation.
The one thing I'm really after is turning off the 3 blinks on the turn signal when you just tap it. I'd really like just a single blink. I've only found docs that show how to do that on the F150.
Does anyone know how to do this on the S550 Mustangs? Specifically I have a 2015 5.0.
Malcolm
MalcolmV8
Re: s550 Mustang codes
Post by MalcolmV8 » Tue Dec 05, 2017 3:38 pm
No Mustang guys out there?
Juice
Post by Juice » Tue Dec 05, 2017 6:32 pm
MalcolmV8 wrote:No Mustang guys out there?
I think there are like 3 or 4 here (including you & me). lol All different years too.
MalcolmV8
Post by MalcolmV8 » Tue Dec 05, 2017 7:13 pm
Ah ok. Wish I knew more about figuring out the codes. Very interesting stuff.
fl3
Vehicle: Ford Mustang 2016 Convertible V6 3.7l
Post by fl3 » Sun Jan 07, 2018 11:39 am
It is the same setting as on the F150. Some guys did this already and it works.
Turn Signal Flashes (# of) SCCM 724-01-01 xxxx x*xx xx 0-3=1 flash, 4-5=2 flashes, 6-7=3 flashes, 8,9=4 flashes, A,B=5 flashes, C,D=6 flashes, E,F=7 flashes
Hope this helps.
Cheers
Falk
MalcolmV8
Post by MalcolmV8 » Sun Jan 07, 2018 6:48 pm
fl3 wrote:It is the same setting as on the F150. Some guys did this already and it works.
Hope this helps.
Cheers
Falk
Interesting. I'll give that a shot and report back. Thanks.
xandergomez
Vehicle: 2016 Mustang 2.3L Ecoboost
Post by xandergomez » Thu Nov 08, 2018 4:36 pm
Hope this helps.
Cheers
Falk
Have either of you guys disabled the Bass clipping on the factory radio?? Thanks!
MalcolmV8
Post by MalcolmV8 » Thu Nov 08, 2018 4:51 pm
I have not messed with the radio or bass clipping. Never did get the turn signals working right either. Got a few other things working which was nice.
cbeech70
Vehicle: 2018 Mustang GT
Post by cbeech70 » Sat Nov 10, 2018 10:25 pm
Has anyone enabled global window up on there s550? Also I would like to turn off the tail lights when remote start. I have been trying different things in order to enable the gear indicator all the time not just when in "S" with no luck. Any ideas????
Yansel
Vehicle: Ford Mustang Ecoboost 2.3L 2017
Post by Yansel » Tue Jan 29, 2019 5:58 pm
Global window up is not possible.
I purchased and installed the cobb accessport v3. After the install I now have gear indicator at all times. Dont know if it cam be done with forscan
