Adjust autolamp sensitivity?
Posted: Thu Nov 30, 2017 9:14 pm
by cr08
Curious if anyone has tackled this or looked into it. Got a 2013 C-Max Energi (North America model) and while I do like having the autolamp feature, I do wish the sensitivity could be adjusted. Seems like it must get pretty dark before it kicks on and I'd prefer it when it is just a little lighter out.
Re: Adjust autolamp sensitivity?
Posted: Sun Jan 07, 2018 11:57 am
by fl3
I am not aware of a configuration setting to adjust the sensitivity. What can be done is shorten the time for the auto light to go on from 20 seconds to around 3 seconds.
For adjusting the sensitivity you probably would need to tweak the sensor. It might be as simple as adding am adjustable resistor in parallel to the existing light sensor...
Cheers
Falk
Posted: Sat Mar 23, 2019 10:26 am
by Eng_adi
Is it possible to change the sensitivity without adding hardware ?
How to reach/adjust this values in attached photo:
