2010-2013 Mazda 3 Cruise Control Activation
amustafa
Vehicle: Mazda3, 1.6 gasoline/105hp, 2012
Re: 2010-2013 Mazda 3 Cruise Control Activation
Post by amustafa » Wed May 15, 2019 10:47 pm
That's weird.
I think the issue with your obd adapter because i faced the same issue with my first one which i bought it from amazon for $17
now i have this https://www.ebay.com/itm/302667604229?h ... 4678652105 for less than $10 and it's working perferctly
zedzed
Vehicle: Mazda 2 DE 2008 1.5 бензин
Post by zedzed » Thu May 16, 2019 5:44 am
I have one idea, but need time....
mitchy_bobby
Vehicle: Mazda 2 2011
Post by mitchy_bobby » Wed May 29, 2019 11:08 am
Hi i am trying to enable cruise control on a 2011 Mazda 2, I have a ELM327 (FTDI) V1.4 works in COM mode. I found that version 2.3.0 didn't find the PCM but version 2.3.22 did, so if you aren't finding the PCM maybe try a different version of FORScan.
I have managed to get FORScan to connect and read the PCM. I have backed it up twice :D
I just wanted to check that i have the PCM calculations correct.
From what I understand only the last four digits of two lines (7 and 25) need to be changed.
The last four digits of 7E0-01-07 are F11E > Should become > F320
The last four digits of 7E0-01-25 are 1B24 > Should become > 1922
Does this sound correct ?
youyoukulude
Vehicle: Ford Escort China,1.5L 122ps,L3 2019
Post by youyoukulude » Wed May 29, 2019 1:40 pm
Study it.
Onh5bu
Vehicle: Mazda 3 1.6 benzinli 2010 105 hp
Post by Onh5bu » Fri May 31, 2019 3:04 pm
Hello great work you do help me in my car mazda 3 2010 turning 1.6 gasoline id: JMZBL14Z501144551 and curiuz control connected can not active pcm is built my data this way.
https://drive.google.com/file/d/1-CBxhE ... p=drivesdk.
I've added the content of my tool pcm pdf as a tool, please help me in my tool, now I have to activate activation. thank you so much
mitchy_bobby
Post by mitchy_bobby » Sat Jun 01, 2019 1:22 am
Onh5bu
you need to change your google drive link to public, it requires a google sign in to view.
Onh5bu
Post by Onh5bu » Sat Jun 01, 2019 1:00 pm
Hello please help waiting for your help you can see the pcm codes of my tool I opened for sharing goole dirivi as you described.
Onh5bu
Post by Onh5bu » Sat Jun 01, 2019 1:03 pm
Onh5bu
Post by Onh5bu » Sat Jun 01, 2019 1:45 pm
Onh5bu
Post by Onh5bu » Sun Jun 02, 2019 3:55 pm
hi friends I mazda 3 2010 1.6 aracma cruise control I don't know how to do the activation process.
https://docs.google.com/document/d/1ZN9 ... p=drivesdk
