2010-2013 Mazda 3 Cruise Control Activation
baxevan
Vehicle: MAZDA2 2008
Re: 2010-2013 Mazda 3 Cruise Control Activation
Post by baxevan » Mon Apr 29, 2019 10:15 pm
It is so frustrating when making so many calculations to correct others mistakes because they didn't watch out when changing stuff.
first insert on the last box of line 25 F5FE and verify that everything is back to normal.
amustafa
Vehicle: Mazda3, 1.6 gasoline/105hp, 2012
Post by amustafa » Tue Apr 30, 2019 5:06 pm
Thank you so much it works you are great man!
Now what should i do?
amustafa
Post by amustafa » Tue Apr 30, 2019 6:44 pm
I think
line 7 should be F320
and line 25 should be F3FC
right?
baxevan
Post by baxevan » Tue Apr 30, 2019 8:33 pm
correct.
amustafa
Post by amustafa » Wed May 01, 2019 5:22 am
Thank you very very much, it works
zedzed
Vehicle: Mazda 2 DE 2008 1.5 бензин
Post by zedzed » Sat May 11, 2019 4:42 am
Hello!!! I want to activate cruise control too. MAZDA 2 DE 1.5 MT 2008. I installed 2.3.16 beta. I can't find pcm in AS BUILT. And now I need help.
https://drive.google.com/drive/folders/ ... sp=sharing
amustafa
Post by amustafa » Mon May 13, 2019 6:47 am
Ok, you have to make a test to PCM when off and on,
"the modules in the picture below", after this close forscan and reopen it, that's it
zedzed
Post by zedzed » Tue May 14, 2019 6:41 am
Thanks for the hope. This magical result was unsuccessful. The miracle did not happen.
zedzed
Post by zedzed » Tue May 14, 2019 6:48 am
Maybe the reason is that in my ELM USB converter is not FDTI, but Prolific?
zedzed
Post by zedzed » Tue May 14, 2019 6:27 pm
Today I tried to connect with ELS27 - again without success. PCM is not available for configuration.
