2010-2013 Mazda 3 Cruise Control Activation
ixtazy
Vehicle: Mazda 2 2007
Re: 2010-2013 Mazda 3 Cruise Control Activation
Post by ixtazy » Sat Apr 13, 2019 1:33 pm
what i need there please help me :(
Avari
Vehicle: 2011 Mazda 3i
Post by Avari » Sat Apr 13, 2019 2:43 pm
In line 7 you added (2) to the F1 making it F3, then fixed the last digit checksum, making it F320.
Now we fix the total checksum on lines 25 - Minus (2) from C5 and then from the line 25 checksum digit.
I think it should be C3CC
baxevan
Vehicle: MAZDA2 2008
Post by baxevan » Sat Apr 13, 2019 6:52 pm
Hey Avari hope you are good. This guy has messed with his values so the 25th line is not his stock one. @ixtazy I have replied to your topic. Do what i wrote and then respond.
Avari
Post by Avari » Sat Apr 13, 2019 9:03 pm
Whoops! Thanks for letting me know
amustafa
Vehicle: Mazda3, 1.6 gasoline/105hp, 2012
Post by amustafa » Mon Apr 22, 2019 5:08 pm
Unfortunately i only have these modules
BCM
IC
RCM
EPS
what should i do ? please help me
baxevan
Post by baxevan » Thu Apr 25, 2019 11:49 pm
try the 2.3.16 beta version.
amustafa
Post by amustafa » Sun Apr 28, 2019 5:19 pm
I tried it and it works, now
i changed the value of "7E0-01-25" like the above image but unfortunately now i have check engine at my dashboard
the error code is P0610
Please help me
baxevan
Post by baxevan » Sun Apr 28, 2019 9:39 pm
line 25 is different in every car.
copy here line 7 and 25 that your car had before you changed anything and i will tell you what to change.
amustafa
Post by amustafa » Mon Apr 29, 2019 2:41 pm
Unfortunately i saved the backup but it saved on the modified data, here's my pcm data
Annotation 2019-04-29 173921.png (23.99 KiB) Viewed 996 times
and also i downloaded the as built data for my car to restore it to default but it display an error: "Number of block file and module doesn't match"
amustafa
Post by amustafa » Mon Apr 29, 2019 3:10 pm
and here's my original asbuilt data, please find the attachment
