2010-2013 Mazda 3 Cruise Control Activation
Avari
Vehicle: 2011 Mazda 3i
Re: 2010-2013 Mazda 3 Cruise Control Activation
Post by Avari » Fri Aug 31, 2018 6:54 pm
Check this table
Purple stuff is your VIN in HEX format. Throw your vin in a hex convertor and it should be the same numbers. Nothing there is changing.
The Red/Blue/Green/Teal are your PCM AS BUILT data. Same data you download from the motorcraft website. In that data is where we make the change for the cruise control (Line 7) F1 to F3, then recalculate the last digit sum (1E to 20) We added 2 to go from F1 to F3 (F1.. F2.. F3), so we add two to 1E (1E.. 1F.. 20) So we get the final value of F320.
So we added two above, and the TOTAL checksum (lines 25/26) require us to minus two to compensate for the addition above. Because F3 is the TENS place for the PCM value, we need to minus 20 from the TENS place of the final checksum.
As we are just changing the total sum value by 20, we don't need to worry about changing the ones place digit. Therefore, we don't edit anything on line 26, just 25. Other changes to the PCM data might require us to, but not for the cruise control PCM change.
Take your line 25 FA value (Tens place of the final checksum) and minus 2. FA - 2 = F8. Then Recaculate your checksum for the line 25. We minused two from the line, so we minus two from the checksum 03 minus 2 is 01.
SpeakEasy
Vehicle: Mazda2, 1.5L, 2013
Post by SpeakEasy » Fri Aug 31, 2018 10:55 pm
Genius!
Thank you for the help, can't wait for this dang wheel to get here now!
renasurgut
Vehicle: mazda3 bl 2010г
Post by renasurgut » Tue Dec 18, 2018 4:46 am
Check this table
forscan will calculate the checksum in line 25 and 26???
Avari
Post by Avari » Tue Dec 18, 2018 5:17 am
You have to calculate the data in the two lines (as the whole checksum) but forscan will calc the last digit individual checksum for the two lines
Avari
Post by Avari » Fri Jan 11, 2019 6:35 am
You get it figured out?
Ilkohristov
Vehicle: Mazda2 1.6 2012 de 95hp
Post by Ilkohristov » Mon Jan 28, 2019 5:58 pm
Warum für meinem mazda2 habe ich dieses Bild
Ilkohristov
Post by Ilkohristov » Mon Jan 28, 2019 6:00 pm
Ich brauche Info für Cruise control Anstellung
Ilkohristov72
Post by Ilkohristov72 » Fri Feb 08, 2019 3:10 pm
7E00101003500060024
7E001023C5E00000185
7E001032512C30413FC
7E001044B080000003F
7E00105000098000085
7E00106000000D701C6
7E001074A0496032A00
7E001080000000000F0
7E00109000000046358
7E001100000000000F8
7E001110007AB09FDB1
7E0011209FD07AB03B5
7E00113A50416047F3D
7E001140000000000FC
7E001150000000000FD
7E00116000000004B49
7E00117014B014B18AF
7E00118000000000000
7E00119000000000001
7E00120000000000008
7E00121000000000009
7E0012200000000000A
7E0012300000000000B
7E00124000000000B17
7E001257300640000E4
7E00126DBCF0001AD66
7E001270C0001480367
7E0012839930000DC
amustafa
Vehicle: Mazda3, 1.6 gasoline/105hp, 2012
Post by amustafa » Mon Feb 18, 2019 8:26 am
I have a standard 2012 Mazda 3 without Cruise control,
Recently I've added a steering wheel with cruise control and also I've changed the clock spring and the brake light switch,
currently I am trying to activate the cruise control through Elm327,
I've downloaded the Excel sheet to calculate the sum for cruise control
I've changed this value : 07 20 04 23 00 00 00 00 00 4E
to this value : 07 20 04 23 00 00 00 00 20 6E
and this value: 07 20 04 01 1E C0 00 00 15 7
to this value : 07 20 04 01 22 0 00 00 15 63
but when I tried to write, the following error shown: Incorrect vehicle conditions
Please help
baxevan
Vehicle: MAZDA2 2008
Post by baxevan » Thu Apr 11, 2019 8:00 pm
Check to see if you can see the pcm configuration block (as built data ) in configuration.
it has all the 7e0 address values. paste it here and i will help you change the values to enable cc. if you cannot find the option try with version 2.3.16beta.
