2010-2013 Mazda 3 Cruise Control Activation
Onh5bu
Vehicle: Mazda 3 1.6 benzinli 2010 105 hp
Re: 2010-2013 Mazda 3 Cruise Control Activation
Post by Onh5bu » Sun Jun 02, 2019 4:08 pm
VictoriaSouth
Vehicle: Mazda3 BL 2010 1.6
Post by VictoriaSouth » Wed Jun 26, 2019 12:02 pm
I set up a cruise remotely, cost $ 14. I am sending detailed instructions.
Without departure to the dealer. ;)
VictoriaSouth@yandex.ru
mitchy_bobby
Vehicle: Mazda 2 2011
Post by mitchy_bobby » Wed Jul 03, 2019 1:45 am
Hi Onh5bu,
I am not an expert, You make these changes at your own risk, Make sure you have a back up of the original lines.
I think the changes are
The last four digits of 7E0-01-07 are F11E > Should become > F320
The last four digits of 7E0-01-25 are E6EF > Should become > E4ED
If this works please let us know.
VictoriaSouth
Post by VictoriaSouth » Wed Jul 03, 2019 8:32 am
I'll make a cruise, 14$. (900 руб.) Гарантия 100%.
Write VictoriaSouth@yandex.ru
mitchy_bobby, line7 F320 & line25 E4ED = Error PCM. Checksum is not correct.
baxevan
Vehicle: MAZDA2 2008
Post by baxevan » Mon Jul 08, 2019 1:35 am
The lines are correct. Quit trying to take advantage of people.
VictoriaSouth
Post by VictoriaSouth » Mon Jul 15, 2019 8:41 am
Rave!
Brum
Vehicle: Mazda 2 + BMW E46 318i
Post by Brum » Wed Aug 21, 2019 8:11 pm
Just came here to activate the cruise control on our ‘08 Mazda 2 (1.3.)
Bought a second hand steering wheel with all the buttons, the 4 pin brake switch and a OBD2 connector for car to laptop (USB.)
I followed the instructions as given in this forum and got it working!
Must say it took me a while before I understood what to do with line 25 in the PCM, but I got it; just extract 2 from the second and last digits from the last group of numbers and letters.
e.g. FGF8 becomes FEF6.
As the order is; a-b-c-d-E-f-G-h and 1-2-3-4-5-6-7-8
I still don’t know what happens if you start with for example FAF1, but I was lucky that mine was easy.
M3 2.0S
Vehicle: Mazda 3 2.0S 2009
Post by M3 2.0S » Wed Oct 16, 2019 4:56 am
Has anyone success in Mazda 3 2.0 4 speeds?
M3 2.0S
Post by M3 2.0S » Sun Oct 27, 2019 3:12 am
I have successfully changed PCM3 by Jamei's tool: FF => F3, but when turning on the cruise control switch on the steering wheel, the cruise light on the dashboard is not lit. The result is similar when changing PCM2 FF => FE. Does anyone know of any other causes that do not trigger the cruise control ? My 2009 Mazda3 2.0L 4 speeds without cc module in forscan, so I have to follow Jamei's way
Tks!
baxevan
Post by baxevan » Thu Nov 07, 2019 9:00 pm
Post your complete 7e0 lines and i will help you
I hope it is the same with auto 4speeds as yours
