2010-2013 Mazda 3 Cruise Control Activation
Avari
Vehicle: 2011 Mazda 3i
Post by Avari » Sun Nov 12, 2017 9:25 pm
I have been searching this forum and the mazda forums trying to find someone who has activated the speed control on a Gen2 mazda 3. Not finding a ton.
Installed Cruise Control switch BEH3-66-4M0C and Brake Pedal Stoplamp Switch BN7N-66-490 for a 2011 Mazda 3 (2010 might be different part numbers, these seem to be for 2011-2013). Did an illumination test and CC lights cam on.
Avari
Re: 2010-2013 Madza 3 Cruise Control Activation
Post by Avari » Wed Jul 18, 2018 11:41 pm
Pulled PCM data from https://motorcraftservice.com/AsBuilt/ and put in my vin and a couple from craigslist.
My Car - 2011 Mazda 3 Sedan 2.0 Manual w/o Cruise
PCM Modules
PCM 1 FFFF FFFF 0310
PCM 2 46FF FFFF FF54
PCM 3 FF41 F1FF FF42
PCM 4 FFFF F0FF FF00
PCM 5 FFFF FFFF FF10
PCM 6 FFFF FFFF FF11
PCM 7 FFFF FFFF FF12
PCM 8 FFFF FFFF FF13
PCM 9 FFFF FFFF FF14
BCE Modules
Module Address Instructions
7C0-01-01
7C0-02-01
7C0-03-01
7C0-04-01
720-01-01 6280 6026 8011
720-01-02 BE00 0CD6 9E68
720-01-03 BF0C D6A0 7AE6
720-01-04 0CD6 9EBB 0C73
720-01-05 D69F 257C 0043
720-01-06 0000 AF01 02E0
720-01-07 1208 26FF 0876
720-01-08 0858 5252 34
720-02-01 BE00 E8
726-01-01 4021 0000 0090
726-01-02 007C AC
726-02-01 E010
730-01-01 0000 004A 4DD0
730-02-01 3142 4C31 557F
730-03-01 4758 4231 3481
730-04-01 3431 3633 313B
730-05-01 0B00 0000 0048
731-01-01
737-01-01 FFAD DB00 C7
773-01-01 C600 0020 0062
And another - 2011 Mazda 3 Sedan 2.0 Auto w/ Cruise
PCM Modules
PCM 3 FF41 F3FF FF44
BCE Modules
7C0-01-01
7C0-02-01
7C0-03-01
7C0-04-01
720-01-02 BE00 0CB0 1ABE
720-01-03 D10C AF82 4A83
720-01-04 0CAF 947C 0C03
720-01-05 AFFF 017C 0058
720-02-01 BE00 E8
726-01-01 4020 0000 008F
726-01-02 007C AC
726-02-01 E010
730-02-01 3142 4C31 5680
730-04-01 3032 3538 343F
731-01-01
And one more -2011 Mazda 3 Sedan 2.0 Auto w/ Cruise
PCM Modules
Avari
Post by Avari » Wed Jul 18, 2018 11:44 pm
From reading the above motorcraftservice ASBUILT data - I can determine that PCM 3 is the only major change.
Here is my ASBUILT PCM data from Forscan attached -
Main question- Why is the PCM Data pulled from Forscan different from what I pulled from the motorcraft website? Where would I test the differences in PCM 3 in the forscan PCM Programming?
They seem similar to 7E0-01-07 but not quite -
Any ideas?
Avari
Post by Avari » Thu Jul 19, 2018 1:09 am
Got a guy with a 2010 Mazda 3 hatchback with the bigger engine and cruise that is going to let me grab his PCM data tomorrow - See if it compares.
Avari
Post by Avari » Thu Jul 19, 2018 2:30 am
https://web.b2b.mazda.co.jp/AsBuilt/
Looks like this page returns the same information as Motorcraft - is there a chance Forscan is giving me incorrect info on the car?
Avari
Re: 2010-2013 Mazda 3 Cruise Control Activation
Post by Avari » Fri Jul 20, 2018 4:44 am
Original - 2011 Mazda 3 5spd 2.0l Base Package Sedan
Alex- 2010 Mazda 3 6spd 2.5l GT Package Wagon
ABT COMPARE.zip
(2.62 KiB) Downloaded 105 times
Avari
Post by Avari » Fri Jul 20, 2018 4:56 am
PCM - 8 Different Values
BCM - 1 Different Value
IC - Lots of different values
EPC - 3 Different Values
RCM - 4 Different Values
Going to start with the PCM as that's the most likely place. I have these as a good backup, what are the chances of bricking the ECU?
http://www.compulsivecode.com/Project_A ... mpare.aspx using this to compare the two sets
Avari
Post by Avari » Fri Jul 20, 2018 5:33 am
This looks like it is indeed similar to Bretman's 2009 Axela like JamieM was talking about before, but changing this value didn't seem to enable the function on my car.
Cruise Control Compare.PNG (5 KiB) Viewed 3225 times
Avari
Post by Avari » Sun Jul 22, 2018 1:29 am
Solved. Jesus that took some time .
If I copy the entire 7E0-01-02 line from the CC enabled car -
3155-4758-4251 > 3148-3636-4110
AND change the known CC enable of 7E0-01-07 from JaimeMs RX8 thread.
FFFF-FF41-F11E > FFFF-FF41-F320
It works. I cant find one data field in 7e0-01-02 that enables or disabled the cruise alone, it seems all three have to be in there. I will try breaking them down more after dinner.
baxevan
Vehicle: MAZDA2 2008
Post by baxevan » Sun Aug 05, 2018 9:31 pm
Hello. I have a mazda 2 without cc and I saw your post. I have the same 7e0-01-07 configuration with you. The thing i don't get is that you changed the 7e0-01-02 too so you basically changed your vin. Can you verify if it was changed?
It doesn't make any sense to change that at all as as built data is seperate from vin...
Can you post your current PCM data (7E0) and post it please?
