Changing radio frequency Ford Fusion 2013
CeresPL
Vehicle: Mondeo/Fusion 2013
Post by CeresPL » Thu Oct 26, 2017 12:54 pm
Hello!
Please help me:
how to change frequency from USA to EU in radio.
Thanks for help.
Weekend
Vehicle: Ford F-150, 5l, 2013 CrewCab
Re: Changing radio frequency Ford Fusion 2013
Post by Weekend » Fri Oct 27, 2017 12:38 pm
The same interesting for F150 2013
Life too beautiful and interesting... Don't worry, be happy.
Был: Contour 2.5 V6 АКПП 95, теперь F-150 5l
omar302
Post by omar302 » Thu Nov 02, 2017 4:25 pm
You need to change the As built Data for the ACM:
727-04-01 x*xx xxxx xxxx
Change “*” for Tuner Region: 0=NA (North America), 1=GCC, 2=Japan, 3=Europe, 4=Asia Pacific
Weekend
Post by Weekend » Mon Nov 06, 2017 11:28 pm
omar302 wrote:You need to change the As built Data for the ACM:
Thank you very much, i'm try with my F-150...
Weekend
Post by Weekend » Mon Nov 13, 2017 7:30 am
Frequency changed fine but No RDS after change, may be some one know why?
Ernest1308
Vehicle: Ford Escape 1.6 182hp 2014
Post by Ernest1308 » Thu Nov 16, 2017 12:32 pm
Hallo everyone!
Forscan does not reflect ACM module, on FUSION 2016. Escape 2014 - ok.
what is the reason?
P.S.: It`s all right.
ausstaddict
Vehicle: ford focus st
Post by ausstaddict » Mon Nov 20, 2017 10:09 pm
i have same issue no option to config acm 2013 focus st.
Weekend
Post by Weekend » Tue Nov 21, 2017 7:18 am
Also in Radio menu can't Off RDS, i'm press to Off RDS and then RDS turn On imediate, but not work at all :(
stundentas
Vehicle: mustang escape c-max about few years old
Post by stundentas » Fri Feb 02, 2018 11:16 am
procedure of usa eu conversion:
727-04-01 x*xx xxxx xxxx Tuner Region: 0=NA (North America), 1=GCC, 2=Japan, 3=Europe, 4=Asia Pacific
second step 727-04-01 xxxx xx** **xx Country Code
APIM configuration and that's all.
finally it works on cars from 2016y without problems
for older need update for acm with IDS .
tested 100 %
cuub
Vehicle: Ford Fusion 2013 2.5L
Post by cuub » Wed Feb 07, 2018 7:31 pm
and how to find correct country code for APIM?
Thanks.
