How to enable line lock on V6 and EB 2015-2017 Mustang
Duane Wertz
Vehicle: 2015 V6 Mustang
Post by Duane Wertz » Tue Oct 17, 2017 3:15 pm
Does any one know how to enable the line lock for the 2015-2017 V6 and E.B. Mustangs. The tool has the commands for the IPC and the ABS but ABS throws codes when enabled. Looked through the Ford parts lists and did not see any difference in hardware. Is there another config parameter that also needs to be programmed to get line lock working on these vehicles, or know of any hardware differences?
cppawlow
Vehicle: 2015 Mustang Ecoboost 2.3L
Re: How to enable line lock on V6 and EB 2015-2017 Mustang
Post by cppawlow » Thu Dec 07, 2017 8:16 pm
Did you try ABS Line lock before enabling in the IPC? I've only done it the other way around and tripped the ABS / Collision Alert warning indicators. I'm going to try doing it the other way around now that I have a battery maintainer cable and don't have to worry about discharging the battery.
I'm curious as to how the values differ in the 2018 EcoBoost Mustang, since it does have Line Lock
fl3
Vehicle: Ford Mustang 2016 Convertible V6 3.7l
Post by fl3 » Sun Jan 07, 2018 11:36 am
For LineLock on EB 2015-2017 Mustang you need to switch the ABS module to a GT one. The programming of the ABS module is different to the GT and does not allow line lock.
They are available on Ebay for not that much money.
A guy in UAE just did it. For details see here:
https://www.mustang6g.com/forums/showthread.php?t=96154
Cheers
Falk
