2010 C-Max Pre production car (no factory asbuilt) need help
HenHen
Vehicle: Mustang Shelby
Post by HenHen » Sun Sep 10, 2017 9:22 am
Hello
I have a 2010 CMax. the BCMii had an error and we exchange it. the install procedure with FDRS and VCM was no problem.
But.
Because the car is a pre procuction car and Ford does not have any ass built data in his system. also the Ford hotline doen not have any idea how to cofigurate the new BCMii correct.
Forscan can also not not config it. the system still has some reeor in the configuration.
any one a idea how to solve this error?
Trabert C-MAX.jpg (220.45 KiB) Viewed 6425 times
mr.singh_vlc
Vehicle: mondeo BA7 2.0 2007
Re: 2010 C-Max Pre production car (no factory asbuilt) need
Post by mr.singh_vlc » Sun Sep 24, 2017 10:23 pm
hei
have the same issue .
have you found the solution??
jzchen
Vehicle: C-MAX Energi, 2.0L I-4, Atkinson/188 hp net, 2013
Post by jzchen » Mon Sep 25, 2017 10:02 pm
Looks like your calibration file folder is not complete. Find the file and put it in the requested folder for SBL?
HenHen
Post by HenHen » Mon Sep 25, 2017 10:08 pm
Where to find this file?
jzchen
Post by jzchen » Tue Sep 26, 2017 6:22 pm
Any files needed may be found here:
https://www.fordtechservice.dealerconne ... roduct=IDS
It is .ZIP and needs to be extracted.
If it keeps asking for the same file, you have not placed it in the correct directory.
HenHen
Post by HenHen » Tue Sep 26, 2017 6:32 pm
download working, extracting too. will see, if its possible to config this car in the next few days.
thank you for the moment
