How to select which front lights are used as DRL (DTRL)
tniemin
Vehicle: Ford Galaxy 2.0 TDCi / 103 kW , 2009
Post by tniemin » Sun Aug 20, 2017 6:21 pm
How to select which front lights are used as daytime running lights?
My car is 2009 Ford Galaxy with automatic lights and the current setting is that there are no lights at daytime (light switch in (A) auto position).
HIDs and tail lights lit up when there isn't enough light on outside...
Is there a way to configure fog lights to work as daytime running lights (DRL)?
Light Switch (auto)
- Bright daytime -> only Fog lights are on
- Darker times -> HIDs and tail lights lit up as it does with current setting.
Any help would be appreciated.
Lambertwang
Vehicle: Ford explorer 2017
Re: How to select which front lights are used as DRL (DTRL)
Post by Lambertwang » Wed Aug 23, 2017 12:38 am
I do not know Galaxy, I got this from F150 /everest forum, someone said they have done that OK , but I can not make it in my 2017 explorer, seems something else need to be discovered.
if set BCM 726-45-01 xxxx 7Fxx xxxx
then BCM 726-50-01 set to below will change the DRL in front
Low Beams - 0280
Front Fog Lamps - 0482
Front Turn Lamps - 0886
Dedicated DRL - 108E
High Beams - 209E
Low Beams and Dedicated DRL - 40BE
Disabled(maybe not) - 017F
tniemin
Post by tniemin » Wed Aug 23, 2017 8:30 pm
Thanks Lambertwang for your answer.
Ok. I'm going to need some instructions to get more options from FORSCan...
How do you get those (AS BUILT format) options visible to "Configuration and Programming" screen?
I've seen some pictures where they have both configuration options available for all modules.
I only have ABS module with AS BUILT, but everything else is in "User Friendly" format (picture attached). :?
I also have Extended license, but do I need something else to get "AS BUILT" editing to show up?
How to get AS BUILT format to all modules?
Configuration and Programming.GIF (89.78 KiB) Viewed 8574 times
Lambertwang
Post by Lambertwang » Fri Aug 25, 2017 12:24 am
hi, did you apply the license for your installed FORScan, if not, I believe that would be reason why you do not have much module listed there. otherwise , I guess you purchased a MS or HS only ELM327 , this action indeed need both MS and HS , normally there is a switch on that.
tniemin
Post by tniemin » Fri Aug 25, 2017 9:01 am
I think I applied the license correctly. At least the app shows that Extended license is valid until... (pic).
...and the adapter is USB Modified ELM327, and I bought it from here:
https://tunnelrat-electronics.fwscart.c ... 45457.aspx
It has that switch and this was recommended by ConversMOD.de
In use there are no errors with MS or HS...
Any ideas?
...because I have none... :?:
FORSCan lic.GIF (126.33 KiB) Viewed 8497 times
ThatOneDude
Post by ThatOneDude » Fri Aug 25, 2017 10:02 am
Can you drop us a screenshot of the Modules tab on the first screen (Vehicle and interface information) while connected to your vehicle?
tniemin
Post by tniemin » Sat Aug 26, 2017 5:54 am
Here is the picture of listed modules (HS/MS).
There's a bit more modules showing than the Config and Programming screen.
Ford Galaxy 2009 modules
Ford Galaxy 2009 modules.GIF (122.25 KiB) Viewed 8469 times
emapco
Vehicle: Ford Explorer Limited+ 2016
Post by emapco » Tue Nov 21, 2017 11:04 am
Lambertwang wrote:I do not know Galaxy, I got this from F150 /everest forum, someone said they have done that OK , but I can not make it in my 2017 explorer, seems something else need to be discovered.
Low Beams - 0280
High Beams - 209E
I'm driving FE Lim+ 2016 made in Russia. Tried it your way. Works like a charm.
Thank you.
Weekend
Vehicle: Ford F-150, 5l, 2013 CrewCab
Post by Weekend » Fri Nov 24, 2017 11:02 am
726-45-01 xxxx ABCD xxxx - for F-150 before 2015 is changing tire size, not DRL types. May be some one know how to change DLR to front fog light insted of main lamps? When i try to setup that value in Forscan, modules return error value.
Life too beautiful and interesting... Don't worry, be happy.
Был: Contour 2.5 V6 АКПП 95, теперь F-150 5l
jzchen
Vehicle: C-MAX Energi, 2.0L I-4, Atkinson/188 hp net, 2013
Post by jzchen » Thu Nov 30, 2017 11:52 am
Settings, if available, should be in BCM. On my wife's '13 C-MAX Energi the options are limited:
DRL on when ignition on
DRL on when not in P (which does not work)
DRL off
May not be available on your '09 I'm afraid....
