2008-2011 Crown Vic Remote Keyless Enable/Disable
Warmouth92
Vehicle: Crown Victoria P71, 4.6L, 2009
Re: 2008-2011 Crown Vic Remote Keyless Enable/Disable
Post by Warmouth92 » Sat Apr 20, 2019 10:23 pm
dw2455 wrote:
Sun May 27, 2018 7:26 pm
Thanks for this post, I have 09 P71 this procedure worked for mine and 2911 is the correct number
Same for my 2009 - changed first group to 2911, fast-turned the key 8 times to program a generic fob.
Agent916
Vehicle: 2007 Ford Crown Victoria 4.6L2V
Post by Agent916 » Sun Apr 21, 2019 8:52 pm
rescue4224 wrote:
Mon Aug 20, 2018 7:34 pm
2009 Crown vic, Has factory Keyless Entry, connected Forscan and found a code in DDM, Code B1150 Radio Frequency Enable Output Shorted to Ground. anyone ever see this code?
I get the same error. Any help on this matter would be very appreciated
ThatOneDude
Post by ThatOneDude » Mon Apr 22, 2019 6:56 am
I found this diagnostic routine after googling that DTC. Pinpoint test N from this PDF might help you to track down your problem. You'll need a multimeter and you'll need to take various trim panels off to get to the test points, but if you follow this procedure, it should help you.
Islam.eltokhy
Vehicle: Ford Mondeo,ecoboost 1.5/157hp/2018
Post by Islam.eltokhy » Mon Apr 22, 2019 1:23 pm
I have programmed 2 additional fobs with remote start using programming slot and start/stop button procedures.
after programming , the new keys are working only if they are in programming slot and cannot work as remote keys , and obviously remote start doesn't work and original keys are still working as remote.
\I know that after programming two new keys , the old keys should be working only in the slot as emergency keys.
is there any way using forscan to reconfigure the keys and swap them to be able to use the remote start function?
Agent916
Post by Agent916 » Mon Apr 22, 2019 6:16 pm
After some digging around, I found that this error is due to the antenna being missing. I just went to a junkyard and took the antenna and harness from a '09 P71, wired it in and now rke works as intended. This thread has been very useful.
Warren603
Vehicle: F350 diesel 2011
Post by Warren603 » Wed Nov 20, 2019 1:34 am
So I get my car to do the programming cycle but it will not recognize my remote and also on forscan trying to program will not recognize my remote 2011 p71
Patriot247
Vehicle: 2009 Crown Victoria 4.6
Post by Patriot247 » Mon Jan 06, 2020 4:51 am
I have a 2009 CVPI. Just enabled RKE via ED15 D600. Good news is that I now have remote keyless entry (awesome thanks). The bad news is my TPMS light flashes and then it stays solid. Drove for 10 miles and the light is still on. Is there a remedy for this? Also, last thing. My rear window defogger no longer works. Any input would be appreciative. Thanks.
