2008-2011 Crown Vic Remote Keyless Enable/Disable
toxic29
Vehicle: 2008 ford crown victoria p71
Re: 2008-2011 Crown Vic Remote Keyless Enable/Disable
Post by toxic29 » Thu Aug 16, 2018 2:45 am
Am missing something? I can not find the part on forscan to edit the hex numbers I was able to get it to work just by editing the the A0-08 from 2815 to 2915. Was the hex part an old version or what?
rescue4224
Vehicle: 2009 CVPI 4.6L
Post by rescue4224 » Mon Aug 20, 2018 1:30 am
Question Will i need the extended license to enable RKE on my 09 Crown Vic?
ThatOneDude
Post by ThatOneDude » Mon Aug 20, 2018 3:24 pm
2815 and 2915 are hex numbers. They just don't have A-F in them in this instance.
Yes. The extended license is available at no cost.
rescue4224
Post by rescue4224 » Mon Aug 20, 2018 7:34 pm
2009 Crown vic, Has factory Keyless Entry, connected Forscan and found a code in DDM, Code B1150 Radio Frequency Enable Output Shorted to Ground. anyone ever see this code?
Victoria82
Vehicle: ford crown victoria police interceptor
Post by Victoria82 » Mon Sep 24, 2018 10:04 pm
no my 2011 ford crown Victoria police interceptor trying to get the remote key entry to work. i tried turning the key 8 time thing i didn't get no lock cycle. on forscan in on the wrench at remote key entry i get a error (service procedure has been interrupted) pop up. but on the chip in ddm configuration (as built format) A0-08 is EC15 D600 007f
A0-01--2A1E 5B20 0165
A0-02--2A1E 5B0B 0151
A0-03--2A1E 5B2C 0173
A0-04--2A1E C1A4 0152
A0-05--0000 0000 00A5
A0-06--2323 2300 000F
A0-07--0000 0000 04AB
A0-08--EC15 D600 007F what do i need to do to get this to work?? please and thanks!!!
ThatOneDude
Post by ThatOneDude » Sun Sep 30, 2018 5:22 am
The bit necessary for RKE is disabled.
Change A0-08 to ED15 D600 and leave the rest for FORScan to calculate.
After this, you should be able to use the service procedure to program a compatible remote. (Don't worry about the ignition on-off part. Using the service procedure is much easier.)
J_b_5_2
Vehicle: Taurus, 3.5, 2013 interceptor
Post by J_b_5_2 » Fri Jan 25, 2019 3:05 pm
How did you find the DDM module to change the values? I'm relatively inexperienced with Forscan. Sorry for the basic question. Is it under config and prog tab? I'm only showing ABS (as built) and IC (as built).
ThatOneDude
Post by ThatOneDude » Sun Jan 27, 2019 6:33 pm
Looks like your ELM is not communicating with the SCP (J1850) side of the network.
HS-CAN network has IC, ABS, PCM, and Fire Suppression Module (if equipped)
SCP network has DDM, IC, LCM, and HVAC (if equipped with EATC)
There is also an ISO 9141 single wire network attached to the Restraints module and Fire Suppression.
Crunchiespg
Vehicle: 2013 ford E350 5.4l
Post by Crunchiespg » Tue Feb 05, 2019 5:23 am
hello! sorry to butt into an only slightly related topic, but I'm hoping you guys can help as you are talking about a topic similar to what im trying to achieve.
ive got a 2103 Ford E-350XL passenger van, it has the interior upgrade package with power locks and windows. so i believe like the crown vic it should have the keyless module but it's deactivated.
can someone give me an idiots guide to how to get started to change this? i have a cable and will download forscan but i didn't want to change anything blindly.
any tips? thank you
ThatOneDude
Post by ThatOneDude » Sat Feb 09, 2019 4:05 pm
The only related thing I could find on the 2013 was a fuse box diagram. Looks like your remote keyless entry is its own separate module. Not sure where it is located. In 1995, it was located near the driver's seat belt mechanism. In 2003 club wagon models, it was located in the side wall behind the driver's seat. If the module is not installed, both of those models instead have a jumper installed between a couple of the wires in the connector.
