Transit MK7 BCMii programming
Hovervan
Vehicle: Transit 2.2L 2007 (2006.5)
Post by Hovervan » Wed Jun 28, 2017 6:27 pm
Hello there,
I have swapped the BCM on my 2008 MK7 transit.
Coded PATS, done PATS module init, no problem at all.
But I cant upload my asbuild data to the new BCM. When I go to special functions - bcm programming - the procedure starts. Warning message....procedure unsafe, connect charger....click start.
Then it installs the SBL, reads out 4 blocks, and then error unable to read 4 other blocks. Procedure failed, contact admin.
What am I doing wrong? :?
Hovervan
Re: Transit MK7 BCMii programming
Post by Hovervan » Tue Jul 18, 2017 11:34 am
Nobody got any idea? :(
Hovervan
Post by Hovervan » Fri Aug 04, 2017 4:38 pm
Really guys, no one who could state if forscan is mainly capable of programming a MK7 BCM or isnt? Or where can I find log files to contact the admin?
Automate
Post by Automate » Fri Aug 04, 2017 6:54 pm
It's not too hard to click a link on the Forscan home page but I will help you :D http://forscan.org/contactus.html
