Lime958
Vehicle: Ford falcon ba xr6 turbo 4ltr 240kw
Post by Lime958 » Sun Jun 21, 2020 11:07 am
please could someone help me my Ford Falcon FG G6E is having problems I cannot get the ICC to go into auxiliary mode to input my phone
Lime958
Post by Lime958 » Mon Jun 22, 2020 10:22 am
Any help would be much appreciated
Android Man
Vehicle: Ford Ranger 2019
Post by Android Man » Sat Jun 27, 2020 4:42 pm
northvibe wrote:
Wed Mar 25, 2020 5:21 pm
awood05 wrote:
Mon Feb 17, 2020 12:04 am
Hello
Does anyone have any codes for a 2020 Explorer?
Specifically looking to:
- Disable the Auto Start Stop
- Enable ‘Bambi’ mode.
Thank you for all the help.
Not a lot of options have been figured out for the 2020 Explorer yet
Here is the list from the forum
https://www.explorerforum.com/forums/th ... on.481800/
I did disable the double honk if you leave the car running with the key on my 2020 explorer xlt.
jejuda wrote:
Mon Feb 17, 2020 3:01 pm
Go to BdyCM As Built scroll down to 726-48-02 change in the first places from x1xx to x0xx. Write changes. Then go into FCIM Configuration and scroll down to "Start /Stop Button Disable" Change Enabled to Disable. Write changes. The go to IPC Configuration scroll down to "Auto Engine Shutdown With Memory" Enable to Disable. This last step is optional, as all it does is shows, is when you start the engine it briefly shows the icon that the system is turned off.
There is probably a function in BdyCM Configuration that controls the 726-48-2 code. I was lazy since I knew the actual code.
FYI the Modules that are Labelled "AS BUILT" contain the actual computer code to control the actions, (hyperflash, TPMS, Bambi Mode, Start/stop, etc). Modules labeled "Configuration" represent how YOUR VEHICLE (Year, Make, Model, Engine ,etc) was originally configured from the factory . The main Modules you will want to change configurations on are "BdcyCM" Configuration, "IPC Configuration", and "FCIM Configuration". My suggestion is that before you go in to directly change the computer code (As built) check out the Configuration list and see if you can just change "Enable to Disable" or "Disable to Enable". Now all the Configurations listed may not be available for change on YOUR VEHICLE, for example you cannot enable, "Fog Lights With High Beams" if the car does not have fog lights.
Hope this helps.
I've been comparing other ford models vs the 2020 explorer and some configs seem about the same and many look different for making changes. The f150 crowd sure has flushed out their configs! I was able to find/document/generate as built files and window stickers for almost every configuration of the 2020 explorer XLT, and using some of the tools can do compares etc. But is it honestly just trial and error figuring these out? or does the ID for the module/config stay pretty similar between models? ie. 726-48-02 is the same setting on f150 vs ranger etc.
Just used what jejuda posted on my 2019 Ranger USA model and it worked in disabling the Auto Start/Stop but also it activated the Brake assist. Don't mind having it but would like a way to deactivate it if I need to. Thanks to all!!!
Woody70
Vehicle: 2012 F150 Lariat EcoBoost
Post by Woody70 » Sun Jul 12, 2020 6:05 pm
tha5150 wrote:
Thu Nov 07, 2019 1:16 pm
Andyfocus wrote:
Wed Nov 06, 2019 10:19 pm
tha5150 wrote:
Wed Nov 06, 2019 8:33 pm
having a tough time finding the place to put my VIN to get my entire restore file, or so i think thats what i am looking for. Screwed up, module backups arent working and need a full restore file to get back to factory.
any help is appreciated. sorry guys, just not seeing where to type in a VIN
2015 f150 xlt
have you tried looking at the first page , number 5 ?
Thanks, i was stuck on #4 for some reason.. Got it, downloaded, no clue what to do with it from here lol. I actually dropped it off at Ford this morning, hope they just reflash it and i can start over.
Tha5150, regarding what do you do after downloading the Motorcraft VIN-specific as-built file, I don't know but I'm looking into it. My 8 year-old F150 is suffering from electrical issues after lightning struck my garage a week ago (F150 was parked inside), and three of the modules (BCM, PCM (ouch) and APIM) keep failing to download the As Built data. I keep getting a "service procedure has been interrupted" message when downloading those three.
I hope I can load the As Built file from Motorcraft, once I figure out how to pull it from the VIN-specific Motorcraft file that I dowloaded (that .ab txt file).
I will update if I figure it out, since you posed the question.
Hudhaifa
Vehicle: 2012 ford focus 2.0 l
Post by Hudhaifa » Fri Jul 24, 2020 6:04 am
Hi everyone
2012 Ford Focus
I have navigation fault when I start the car and I will change the gps antenna With better one I think will gone ?
And the main thing I can’t do it is the Voice command on steering wheel control with sync 3 I can’t find the any number in forscan Forms
anyone can send me how to active the voice command in sync 3 using forscan plz
zivnic
Vehicle: Ford Focus MK3
Post by zivnic » Sun Aug 09, 2020 6:53 am
Hi, do you have any one already AS-BUILT data spread sheet for Focus MK4? I would like to set in IPC boost gauges as it has MK4 ST, but no luck so far. Thank you!
raym@firematic.com
Vehicle: ford 2.7l 2018
Post by raym@firematic.com » Tue Aug 11, 2020 7:45 pm
17LimitedExpy wrote:
Sat Mar 31, 2018 11:00 am
Here's a link to the Google Doc I've put together for 2015-2018 Ford Expeditions...Admin, please include in the original (first) posting if you think it's valuable to other Expedition owners.
Thanks.
https://docs.google.com/spreadsheets/d/ ... sp=sharing
Hi, do you have anything for the 2019-2020 expedition
RaiderSmiley
Vehicle: F150, 2.7 EB, 2018
Post by RaiderSmiley » Fri Aug 21, 2020 4:38 pm
Thanks.
Will this also work on 2017 Lincoln Navigator L Reserve?
jschneiter
Vehicle: 2015 Ford Explorer Limited
Post by jschneiter » Sat Aug 22, 2020 4:33 am
I dont see anything about Sync 2.0 or IPC 11-15
I have a 15 Explorer
I am trying to put the Climate back on the little IPC Screen
I am also looking to enable navigation while driving but the codes are the same I have 4341 as a code but no idea what to change it to
Any thoughts??
jschneiter
Post by jschneiter » Sat Aug 29, 2020 12:37 am
Anyone? Is it possible?
