2016 F150 Global Windows
ThatOneDude
Re: 2016 F150 Global Windows
Post by ThatOneDude » Fri Oct 06, 2017 9:16 am
Just to cover all bases, are you leaving the data where the x's are what they were before?
ClockWorK
Vehicle: 2015 Taurus SHO pp
Post by ClockWorK » Fri Oct 06, 2017 11:12 am
If it's an 'invalid checksum' error, ignore it.
Sirikenewtron
Vehicle: F150 2.7 Ecoboost 2017
Post by Sirikenewtron » Mon Oct 09, 2017 8:57 pm
mct2green wrote:2016 F150 xlt. I cannot get global windows to work. Error when writing says bad data. Tried multiple times. Any advice?
By chance did you ever get this figured out? I’m having the same issue, 2017 f150
Lance954rr
Vehicle: 2017 F150 2.7l
Post by Lance954rr » Sat Jan 13, 2018 1:46 am
I tried a few times earlier and had the same problem with my 17'. I looked it up and found the issue. So what you have to do is write the first 2 lines, cycle power, write the next line, cycle power, write the ddm, cycle, write the PDM, cycle and you should be good to go. I'm going to try tomorrow
sixty5low
Post by sixty5low » Thu Jan 18, 2018 7:34 am
For some reason when I get it to work, it's just the drivers window. Any help would be greatly appreciated.
thahakk
Vehicle: F-150 Limited, 3.5L Ecoboost 375 Hp, 2016
Post by thahakk » Fri Jan 19, 2018 5:48 pm
sixty5low wrote:For some reason when I get it to work, it's just the drivers window. Any help would be greatly appreciated.
Be sure to write the code to the PDM as well. I printed off the spreadsheet and forgot to change the PDM code as it was on the next page. Only Drivers side window worked until I changed PDM as well.
sixty5low
Post by sixty5low » Sat Jan 20, 2018 2:02 am
That was exactly it, I printed it 3 times and finally realized it was on the top of the next sheet.........
Thanks for the help
mrjoecanadian
Vehicle: 2015 f150 2.7 eco
Post by mrjoecanadian » Mon May 14, 2018 11:20 pm
Lance954rr wrote:I tried a few times earlier and had the same problem with my 17'. I looked it up and found the issue. So what you have to do is write the first 2 lines, cycle power, write the next line, cycle power, write the ddm, cycle, write the PDM, cycle and you should be good to go. I'm going to try tomorrow
I am in the middle of doing this I have the BCM done but dont know how to do the DDM or PDM or is that under PCM in forscan, Im scared to mess that up. I have done the bambi mod but that has been it.
Vladsky
Vehicle: 2017 Ferd PHEV
Post by Vladsky » Tue May 15, 2018 11:10 am
mrjoecanadian wrote: I am in the middle of doing this I have the BCM done but dont know how to do the DDM or PDM or is that under PCM in forscan, Im scared to mess that up. I have done the bambi mod but that has been it.
Howdy;
So - What's the issue here, eh? DDM and PDM are just additional modules - part of a vast list - (and no, NOT in the PCM, lol), like the BCM. They WILL show up in yer discovered modules list under Forscan - Provided you have a fully functioning HS/MS CAN adapter, licensed v2.3.14 Forscan fer Windows installed and running, and are successfully connected to yer truck.
All three modules need to be accessed and changed for this to work. Always a good practice to do module resets (under the wrench icon) after said changes. Actually - after ANY changes - especially to the BCM. There is no real need to repeatedly cycle power that way.
AFTER SAVING ALL of yer As-Built module data, just complete the changes in each as clearly specified in the spreadsheet - found in the linked information sources here: http://forscan.org/forum/viewtopic.php?f=16&t=4393 . Backups will go a long way in alleviating yer concern about "messing up", as yer just a Restore away from recovering from a coding error. Savvy?
If you don't see DDM (Driver door module) and PDM (passenger door module) in yer application's list, you need to read / re-read the tutorial regarding how to use the tool and adapter. Because, you've then clearly done something wrong, aight? Da. :mrgreen:
Salut
Vlad
mrjoecanadian
Post by mrjoecanadian » Thu May 17, 2018 8:43 pm
Vladsky, thanks for the info.
I am guessing I just do not have a fully functioning HS/MS CAN adapter, it worked for the bambi mod but I didn't need anything but the BCM to make that work.
