Master List of Ford As-Built data modifications.
zombieautotech
Vehicle: 2003 Ford Explorer
Post by zombieautotech » Sun Jul 31, 2016 6:22 pm
I thought it may be a good idea to have a list of known as-built data changes for Ford's in one thread. Everyone is welcome to post known AB data modifications. I can add everything into this post. I am not taking any credit for any of these findings, just posting what I have found so it can all be in one spot. Remember, change this AB data at your own risk. This is just accumulated data changes.
Double Honk Disable:
Ford Explorer Double-Honk disable (2014 year model):
BdyCM 726-16-01 0111 56 (Double Honk Enabled, Default)
BdyCM 726-16-01 0101 46 (Double Honk Disabled)
Ford F-150 Double-Honk disable (2015 year model):
BdyCM 726-41-02 0001 0001 0173 (Double Honk Enabled, Default)
BdyCM 726-41-02 0000 0001 0172 (Double Honk Disabled)
Ford Fusion Titanium (2014 year model):
BdyCM 726-41-02 0001 0001 0072 (Double Honk Enabled, Default)
BdyCM 726-41-02 0000 0001 0071 (Double Honk Disabled)
Keyless Entry Enable:
Ford Taurus Police (Interceptor Sedan) enable key less entry (2013 year model):
BdyCM 726-18-01 0000 0000 46 (Keyless Entry Disabled)
BdyCM 720-01-03 8008 0000 B3
BdyCM 726-18-01 0100 0006 4D (Keyless Entry Enabled)
BdyCM 720-01-03 8088 0000 33
Last edited by zombieautotech on Thu Aug 04, 2016 4:58 pm, edited 3 times in total.
ClockWorK
Vehicle: 2015 Taurus SHO pp
Re: Master List of Ford As-Built data modifications.
Post by ClockWorK » Tue Aug 02, 2016 6:13 pm
I agree we do need a list.
I'm hesitant to post anything I haven't directly tested myself. And even then, I can only speak for the one vehicle I have to test with.
mrdot
Vehicle: taurus police
Post by mrdot » Tue Aug 02, 2016 11:58 pm
Ford Taurus Police (Interceptor Sedan) enable key less entry (confirmed on 2013):
BdyCM 726-18-01 from: 0000 0000 46 to: 0100 0006 4D
BdyCM 720-01-03 from: 8008 0000 B3 to: 8088 0000 33
I tested this and it's working great. Must follow key programming instructions after enable.
rotax34078
Vehicle: focus mk3 2.0 2013
Post by rotax34078 » Thu Aug 04, 2016 2:34 am
do someone has a north amercian mk3 focus whithout drl?
i has access to ford's as built database. only need a vin so i can compare with mine.
zombieautotech
Post by zombieautotech » Thu Aug 04, 2016 4:53 pm
rotax34078 wrote:do someone has a north amercian mk3 focus whithout drl?
I would try looking on ebay or autotrader. They usually list VIN numbers.
Schimi
Vehicle: FORD Explorer 2013 Sport
Post by Schimi » Fri Aug 05, 2016 1:14 pm
Ford Explorer 2013 Sport
7D0-02-01
5553 0004 0086 to 5753........ (could use the nav in car motion)
7D0-02-02
8200 0000 005D to 8208........ (Nav Speed cameras enabled)
7D0-01-01
A221 9001 E916 to ....9011.... (TMC enabled / don´t work on my explorer (maybe hardware needed?) but the option is available)
7D0-01-01
A221 9001 E916 to ....9101.... (EU-E-Call enabled / 0 = US E-Call)
720-01-02
F42C 0862 984C to ....0062.... (Fog-Lamp indicator in instrument cluster OFF, usefull if you like use the Fog-Lamps as DaytimeRunningLamps)
Schimi
Post by Schimi » Wed Aug 17, 2016 3:35 pm
could someone make this thread "sticky"?
and delete this post...? :-)
ClockWorK
Post by ClockWorK » Wed Aug 17, 2016 3:52 pm
There appears to be a lot of 2015-2016 F-150 AsBuilt info here:
http://www.f150forum.com/f118/forscan-s ... ck-348987/
There's a spreadsheet link in the first post.
seandevero
Vehicle: 2013 Taurus Interceptor N/A 3.5 awd
Post by seandevero » Mon Aug 29, 2016 11:05 pm
Just confirmed keyless entry on 2013 Ford Interceptor Sedan.
The 720-01-03 line is located in the IPC as-built.
The 726-18-01 line is located in the BdyCM as-built.
wystewart
Vehicle: Mustang GT, 5L, 2014
Post by wystewart » Tue Aug 30, 2016 3:09 am
ford Mustang 2014 GT with Sync1 system, enable backup camera appears to be:
727-01-01 xxxx xxxx 80 to 727-01-01 xxxx xxxx 90 (or possibly OR value with 10)
