Ford As Built Data Deciphering
omar302
Re: Ford As Built Data Deciphering
Post by omar302 » Sat Apr 14, 2018 6:50 pm
So today I figured out 2 more mods (these worked on my 2016 Edge Sport with MyFord Touch (Sync2):
1st, is the country of the IPC:
720-04-02: XXXX xx   -  US default is 5553. On my Edge it was 5141. So what I found changing it  is that I get different language options for the IPC. Like I had English (UK), French & Arabic, while US will get English (US), Spanish & French. Also, with English (UK) the door open warning states Door "Open" instead of "Ajar" for US. Just some language differences.
2nd: This is probably only a Sync 2 (MFT) thing:
7D0-01-01: xxxX xxxx xx   -  My default was "A", adding 4 changed it to "E", when you turn off the ignition you usually get a quick Ford logo shutdown animation on the MFT 8" screen, with this edit, you'll instead get a black screen with the date & time that will remain there for a while or until you lock the vehicle. Note that the date format depends on the MFT language pack, since mine has the EU pack the date is in EU format (month in the middle).
IPC Languages - QA
IPC Country 5141 - Copy.jpg (539.35 KiB) Viewed 7652 times
IPC Languages - US
IPC Country 5553 - Copy.jpg (546.58 KiB) Viewed 7652 times
Date Display
Date Display - Copy.jpg (633.4 KiB) Viewed 7652 times
eng_mhd
Vehicle: Ford Taurus
Post by eng_mhd » Sun Apr 29, 2018 1:44 pm
omar302 wrote:So today I figured out 2 more mods (these worked on my 2016 Edge Sport with MyFord Touch (Sync2):
I think 5341 not 5141
omar302
Post by omar302 » Wed May 02, 2018 11:17 am
5141 is for Qatar. It is what came from the factory.
Rodrigo
Vehicle: Ford Fiesta mk7
Post by Rodrigo » Wed May 09, 2018 12:23 am
Hello everyone, I would like a help, I need to know what each line of the "descontraido module" of my Fiesta MK7 1.6 Sigma Brasil, alters, I have the information but I can not identify what each line does.
I wanted to understand each row representing which functions, I'm using the information from F150 and Fusion, but the modules and rows are not the same.
I'm using this site to pick up Fiesta information so I can identify the rows to set up the same Fusion and F150 table we have available here.
http://ford.xtlt.ru/ab/
7D0-01-01 0210 1B88 008E
7D0-02-01 0442 5200 0072
7D0-02-02 00DB - -
720-01-01 0029 - -
720-02-01 012B - -
720-03-01 7C1E 0C1F 00F0
720-03-02 0A06 2460 -
720-04-01 012D - -
720-05-01 012E - -
720-06-01 012F - -
720-07-01 406F - -
720-08-01 2837 0346 07DF
720-08-02 710C 009B 0049
720-09-01 01EA 001C -
720-10-01 0139 - -
720-11-01 013A - -
720-12-01 003A - -
720-13-01 013C - -
720-14-01 0F4B - -
720-15-01 013E - -
726-01-01 9600 1EF0 FFD2
726-01-02 FFFF FFFF FF2B
726-01-03 FFFF 002F -
726-02-01 051E 0101 0055
726-02-02 323C 100000 FFC1
726-02-03 FFFF FFFF FF2D
726-03-01 4600 2805 00A4
726-03-02 053C 2D41 00E1
726-04-01 FFFF 00101 FF31
726-04-02 FFFF FF30 -
726-05-01 0134 - -
726-06-01 0800 080D 0859
726-06-02 0C01 3031 32D5
726-06-03 3232 908 08B3
726-06-04 FFFF FFFF FF32
726-07-01 FFFF FFFF FF30
726-07-02 FFFF FFFF FF31
726-07-03 FFFF FFFF FF32
726-07-04 FFFF FFFF FF33
726-07-05 FFFF FFFF FF34
726-07-06 FFFF FFFF FF35
726-07-07 FFFF 0039 -
726-08-01 0001 010D 0045
726-08-02 0001 0100 0039
726-08-03 FFFF FFFF FF33
726-08-04 FFFF FF36 -
726-17-01 03FF 03FF 034C
726-17-02 FF03 FF03 FF49
726-17-03 03FF 03FF 034E
726-17-04 FF03 FF03 FF4B
726-17-05 03FF 03FF 004D
726-70-01 0380 0380 03A7
726-70-02 8003 8003 8025
726-70-03 0380 0380 03A9
726-70-04 8003 8003 8027
726-70-05 0380 0380 0A8
726-73-01 00FF 32 00D2
726-73-02 6400 4600 64B0
726-73-03 0003 00FF 01A6
726-73-04 FF00 FF01 FFA2
726-73-05 00FF 01FF 00A4
726-74-01 019F 0101 0145
726-74-02 0101 0100 C86E
726-74-03 0101 019F 0248
726-74-04 8001 9F02 8047
726-74-05 019F 0280 00C8
726-75-01 00262 0202 020D
726-75-02 0202 0201 5E09
726-75-03 0202 0262 0310
726-75-04 0002 6203 000D
726-75-05 0262 0300 000E
726-76-01 033E 0303 03EE
726-76-02 0303 0302 8A3A
726-76-03 0303 033E 03F0
726-76-04 8403 3000 84F3
726-76-05 033E 0384 0070
727-01-01 0232 - -
737-01-01 3942 465A 449F
737-01-02 3535 5036 4576
737-01-03 4236 3539 345C
737-01-04 3931 00AD -
737-02-01 0368 2000 00CC
737-02-02 0C6D 00BB -
737-03-01 0F51 - -
737-04-01 0043 - -
737-05-01 4745 00D0 -
737-06-01 0000 0045 -
760-01-01 3139 3439 3575
760-01-02 3642 4536 50AD
760-01-03 3535 445A 46B9
760-01-04 4239 00E7 -
760-02-01 2164 1113 0013
760-02-02 0000 006B -
760-03-01 55C0 - -
7A5< C1BT-18B955-BD< <C1BT-14D359-BD< <C1BT-14D358-BD< <C1BT-14D356-BB< <
7D0< AV1T-14F130-AA< <AM5T-14D212-KB< <BM5T-14D205-AC< < <
7E0< C1BA-12B684-AB< <EA6A-12A650-BG< <EA6A-14C204-BG< < <
7E1< AE8P-14F085-AC< <CA6P-7Z369-JE< <CA6P-7J104-JE< < <
720< C1BT-14C226-AD< <D2BT-10849-FBJ< <C1BT-14C026-BC< <C1BT-14C088-AJ< <C1BT-14C026-AJ<
726< AV1T-14F156-EF< <AV1T-15K600-EJ< <AV1T-14C100-AJ< < <
727< AM5T-18C815-PE< <N/A <AM5T-14C044-PE< <AM5T-14C230-PC< <
730< AE81-3C579-ED< <AE81-14C217-ED< <AE81-14C262-BA< < <
733< D3BT-14C239-AB< <D3BT-18C612-AC< <D3BT-18D620-AC< <D3BT-18D619-AC< <
737< D3BT-14F136-AB< <D3BT-14B321-AD< <D3BT-14C098-AD< <AV1T-14C028-AE< <
740< CV1T-14F142-AA< <CV1T-14B531-AF< <CV1T-14C064-AF< < <
741< CV1T-14F144-AA< <CV1T-14B533-AF< <CV1T-14C108-AF< < <
760< D2BC-14C602-XX< <D2BC-14F065-AA< <D2BC-2C219-AC< <D2BC-2D053-AC< <
720< < <
726< < <
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
612</ERRORCODE><ERRORMSG>
PCM
DATA
NOT
FOUND</ERRORMSG></ERROR></VEHICLE></AS_BUILT_DATA>
dG bOY
Fiesta mk7 - 1.6 Sigma PowerShift
Rodrigo
Post by Rodrigo » Tue May 15, 2018 12:03 pm
This option in the engine configuration, which appears as "96 - Unknown" is in fact the Ford Motor 1.6 Sigma 1.6 in Petrol, even motorized in Focus only with change to 135CV.
Fiesta 2014 > Ford Sigma 1.6 125 hp (96 - Unknown - I'm looking for the focus code)
Engine: ............................................... Ford Sigma 1.6 16V TiVCT Flex
Number and arrangement of cylinders: ... 4 in line
Diameter of cylinder: ......................... 79.0 mm
Pitch stroke: ........................... 81.4 mm
Displacement: ......................................... 1.6 (1,597 cm³)
Power: 130 hp at 6,500 rpm (ethanol)
125 hp at 6,500 rpm (petrol)
Torque: .............................................. 157 Nm at 5,000 rpm (ethanol)
151 Nm at 4,250 rpm (petrol)
Slow speed: 780 rpm
Maximum rotation: .............................. 6,720 rpm
Compression Ratio: ................... 12,0: 1
Fiesta 2014 > Ford Sigma 1.5 107 hp - Ford Sigma 1.5 Flex N-VCT
Engine: ............................................... Ford Sigma 1.5 Flex N-VCT
Stroke of the pistons: ......................... 76.4 mm
Displacement: ......................................... 1.5 (1.499 cm³)
Power: ........................................... 111 hp at 5,500 rpm (ethanol)
107 hp at 6,500 rpm (petrol)
Torque: .............................................. 147 Nm at 4,250 rpm (ethanol)
145 Nm at 4,250 rpm (petrol)
Slow speed: 780 rpm
Compression Ratio: ................... 11,1: 1
Focus 2014 >Ford Sigma 1.6 150 hp
Displacement (bore x stroke)/Type: 1,595 cc (1.595 L; 97.3 cu in) (79 mm (3.1 in)?x81.4 mm (3.20 in)?) I4
Power@rpm: 150 PS (110 kW; 150 hp)@6900
torque@rpm: 162 N⋅m (119 lb⋅ft)@5600
Compression (:1): 11.0:1
dG bOY
kb1dvg
Vehicle: 2018 Ford Escape SE
Post by kb1dvg » Wed May 16, 2018 7:10 pm
Any assistance on a build sheet for a 2017 or 2018 Escape SE or Titanium?
Rodrigo
Post by Rodrigo » Wed May 16, 2018 7:17 pm
kb1dvg wrote:Any assistance on a build sheet for a 2017 or 2018 Escape SE or Titanium?
Colleague, in fact the deconstruction of the "as built" of the Fiesta is very complex because there is nothing on the internet, only the F150 and Fusion, "as built" of the Fiesta is different from these cars and even the Focus that in Brazil shares the same Sigma 1.6 engine, I'm slowly trying to get the information out.
In Brazil There are several versions of Fiesta, S, SE, SEL, Plus, Titanium and each one changes something.
dG bOY
oslowek
Vehicle: fiesta mk7 2012 1,0 100KM / mondeo mk5 2015 150KM
Post by oslowek » Tue Jun 19, 2018 10:54 am
Hi again,
I have bought F6 SD card and navigation was activated on my sony radio, already.
Used camera from other mondeo was bought and installed, too. Working almost very well. Almost because I see on my sony full rear view from original camera but I can`t see dynamic lines connecting with steering wheel movement. Only I see static lines (green, orange and red). Camera activated was only in APIM 7D0-01-01. I changed only second bit (xXxx xxxx xxxx) from 8 to A.
What should I change to active dynamic white lines, yet?
Best regards
Ondraszek
Alioda
Vehicle: Ford Kuga MK2 1.5L EcoBoost Petrol 180PS 2017
Post by Alioda » Tue Aug 07, 2018 5:03 pm
seniorgeek wrote:
Tue Mar 13, 2018 5:34 pm
I also have a Focus MK3 with the same climate change added to my Sync3 screen.
I also have TPMS to Sync3 via Android Auto.
https://i.imgur.com/w10w0oh.jpg
Which app do you use to display the TPMS via Android auto, is it still working after Google have closed all 3rd party apps?
FE Turbo
Vehicle: Ford Focus RS
Post by FE Turbo » Fri Aug 24, 2018 8:09 pm
I recently upgraded my screen and APIM from Sync 2 to Sync 3 in my 2016 Ford Focus and noticed that the auto dimming feature does not work with the Sync 3 unit. I have enabled the auto screen dimming setting in the Sync 3 screen options, but the screen remains in day-time mode no matter what time of the day it is, or whether the headlights are switched on or not. I can however activate night-time mode manually within the settings, but would prefer the auto dimming of the screen.
Does anybody know whether the auto dimming feature could be enabled via Forscan and what the code is?
