Gary_Robinson
Vehicle: Ford Transit Connect
Post by Gary_Robinson » Sat Oct 24, 2020 7:32 pm
2011 Transit Connect - I don't get a Central Config selection is this normal for this vehical?
I don't get engineering 1 or 2 either of course.
estebanfree
Vehicle: BMW F25 X3
Post by estebanfree » Fri Nov 06, 2020 5:53 pm
I have same problem. did you find any solution about it? thanks
Dex
Vehicle: FORD FOCUS, ECOOBOST 1.0/74KW, 2017
Post by Dex » Mon Nov 09, 2020 5:26 pm
Engineering 1 or 2 is part within central configuration (CC), so if you dont have CC then you cant see engineering.
Idk if that car have CC or not.
But if you use right adapter and all modules get readed (hs and ms can) then you dont have it.
After conection to vehicle forscan first read modules from one can, then ask user to change switch to other can and after user confirmation forscan read that second can.
If thats the case and all pass like i writed, then you have proper adapter and your car dont have CC.
296353809
Vehicle: mazda atenza py2.5。 2017
Post by 296353809 » Mon Nov 23, 2020 6:57 am
Mazda AB obtains the website using the IE browser of Windows 7, the version is IE9
Link is https://web.b2b.mazda.co.jp/AsBuilt/Com ... rPage.aspx
RSWRC
Vehicle: Ford S-Max 2.0Ecoblue 110kw m.y.2019
Re: Jak naprogramovat centrální konfiguraci pomocí FORScan
Post by RSWRC » Wed Nov 25, 2020 9:32 am
Hello, I use Ford VCMM for Forscan.
I understood correctly that if I want to change the SW version of eg IPC unit from the original: JM2T-14C026-JF to: JM2T-14C026-JD
So I will write and download it according to the instructions here: https://www.fordtechservice.dealerconne ... rogram.asp
And using Forscan will I load another SW?
The point is that this new SW shows the range of fuel over 1000km. Not up to 999km.
My VIN: WF0JXXWPCJKE82913
VIN of the mentioned vehicle: WF0JXXWPCJJB69847
They are the same almost the same. It's just a different date of manufacture.
Thank you
zivnic
Vehicle: Ford Focus MK3
Post by zivnic » Thu Dec 10, 2020 6:13 pm
Hello, do you know any one as-built data for setting DRL in "0" position in Focus MK4? When I have it now on "0", all lights are off. But when I had Puma for few days from Ford, there was DRL also on "0" and also in Mondeo MK5 we have it like that. Thank you.
mustafakartal
Vehicle: FİESTA 2010 1.4
Post by mustafakartal » Thu Dec 10, 2020 7:54 pm
2010 Fiesta ya 2012 USB li teyp ünitesi taktım USB yi aktif etmek için forscande ne işlem yapmam lazım
Vehicle: *** Ford ***
Post by f-wolf » Thu Dec 10, 2020 8:34 pm
https://www.google.com/search?q=transla ... &ie=UTF-8
mustafakartal
Post by mustafakartal » Thu Dec 10, 2020 9:38 pm
I inserted a 2010 fiestama 2012 tape, what should I do to work with usb
mustafakartal
Post by mustafakartal » Thu Dec 10, 2020 9:39 pm
