alexixbox
Vehicle: Kuga 1.5L flexfuel E85 Vignale - 2019 FRANCE
Post by alexixbox » Wed Oct 02, 2019 1:12 pm
I have the 2019 KUGA flexfuel E85 1.5L Ecoboost in France. I'm not able to get into BdyCM (Main) - central configuration, getting loading sbl failed message. It can't read block 1/6 then says service interrupted. Anyone can help?
I have WINT ODB2 USB interace https://www.amazon.fr/gp/product/B06XJ6 ... UTF8&psc=1
I succeed to add climate control and temperature on SYNC 3 screen with :
APIM - Climate button on Sync 3 screen
7D0-01-02: xxxx x3xx xxxx
APIM - See set climate temperature on Sync 3 screen
7D0-04-01: xxxx xxx0 xxxx
Thanks for your help
IronCross82
Vehicle: 2017 F150 3.5l
Post by IronCross82 » Thu Oct 24, 2019 5:48 pm
Does anyone know if Forscan can change turbo boost pressure?
thanks again Scott
TimFor
Post by TimFor » Mon Nov 04, 2019 9:25 am
2.3.25 beta, 2019-09-28 says:
"+ Configuration and programming function "Central Configuration" for Mazda SKYACTIV
* Fixes and improvements in Central Configuration function (added missing parameters and values, fixed bugs etc) for Focus, C-Max, Kuga, Escape, Mondeo, S-Max, Ranger, Everest, Transit and Transit Connect family, added missing support for Transit Courier (B460)"
I'd still like to see a reply to my question:
TimFor wrote:
Sat Aug 10, 2019 1:37 pm
FORScan wrote:
Thu Jun 09, 2016 11:24 am
Focus Mk2 has no central configuration. Only Mk3/3.5 have one. Please use ElmConfig for Mk2 configuration programming.
This was written in 2016. What's the situation now? Does FORScan cover all of ElmConfig?
jrhollins1975
Vehicle: Fords Fiesta & CMax 2016
Post by jrhollins1975 » Mon Nov 04, 2019 5:09 pm
This is probably a really stupid and obvious question,but I have been searching the forums for a few hours now and although a similar question to mine has been asked several times it doesn't seem to have an answer.
I have installed Forscan on my windows 10 pc and am using a modified ELM327 connector. I have registered the software with the trial extended licence and have connected without issue to My UK 2016 Ford Fiesta Titanium 1.0 Eco boast.
I have just retro-fitted a factory SAT nav and I need to change MFD4 to MFD5 and Change the NAV unit to EU. Now these changes need to be made in ~Engineering mode, however I do not have this option under configuration and programming.
Even when I use the system in Demo mode the engineering options are not presented.
The opening page of this forum mentions Fiesta family is this going to be the reason. Or do I have to pay for a 1 year licence which if it works I am more than happy to do. Kinda struggling as I cant get my tip meter out of KM at moment
jrhollins1975
Post by jrhollins1975 » Tue Nov 05, 2019 8:35 am
Just an update, yes I was right it was a stupid question. I just needed to choose the central configuration and select the play button. Duh!!
alexixbox
No acces to Central Configuration BdyCM Main using FORScan in KUGA 2019 flexfuel 1.5L Ecoboost E85
Post by alexixbox » Sun Nov 10, 2019 9:16 am
Is there anybody can help me ?
naym ravate
Vehicle: Ranger 3.2 2015
Post by naym ravate » Mon Nov 11, 2019 2:42 pm
MORNING .I NEED HELP I AM MOZAMBIQUE I GOT TIS ISSUE IN MAZDA BT 50 2011 MODEL
I NEED TO USE FORSCAN TO SOLVE
===IPC DTC U2300:56-28===
Code: U2300 - Central Configuration
Additional Fault Symptom:
- Invalid/Incompatible Configuration
Status:
Module: Instrument Panel Control Module
Freeze Frame :
-REALTIME: 143234246 s - Total time ECU has been active
-TOTAL_DIST: 0.0 km - Total Distance
-MAINECUV: 12.25 V - Main ECU voltage supply
-OUTDR_TMP: -40 °C - Outdoor Air Temperature
-PWR_MODE_QF: Power Mode OK - Power Mode Quality Factor
-PWR_MODE_KEY: Key Out - Power Mode Key State
===END IPC DTC U2300:56-28===
lukestafford1
Vehicle: Ba falcon xr8, 5.4l boss, 260kw, 2004
Post by lukestafford1 » Fri Nov 29, 2019 2:22 pm
can anyone help me with finding asbuilt data for my 2004 ba fairmont mkII.
prokerem
Vehicle: ford focus
Post by prokerem » Mon Dec 02, 2019 1:17 pm
I have a 2015 1.6 TDCI Trendx Ford Focus which is 95hp.
I want to change config to 115Hp.
I have succeed to change Engine selection by configuring BCMii and write it to car.
I guess second step to complete this operation is to run "PCM reinitialize/learn".
When i try to run that, i get an error message as "service procedure has been interrupted" at %1 and it does not continue/complete.
I get many DTCs because of that i am not able to run PCM initialize/learn.
If I change engine selection back to original and reset DTCs there is no problem. But i want to complete 95hp to 115 hp operation.
Do you have an idea about why i get an error message at PCM initialize/learn function run?
I have the latest version of Forscan 2.3.26 beta with extended license.
ı have tried different driver for ELS27 I have and also have tried different combinations of driver version / forscan version.
No solution yet.
TheMechanic
Vehicle: XL/5.4 triton V8 /2009
Post by TheMechanic » Thu Dec 05, 2019 10:41 pm
I upgraded the interior in my 2009 f150 to leather heated seat with climate control.ive read the configuration posts and am still trying to recofigure the climate control module.Can any one help me with what i need to do>?
