CLCHEE
Vehicle: FireStar MK7
Post by CLCHEE » Tue Sep 25, 2018 2:53 am
Hi There,
I am trying to clear ABS & TCS fault codes and at the same time activate fog lamp switch and auto-lock function.
I followed instructions from this thread. I've downloaded FORScan version 2.3.16 beta for Windows and got the Extended License applied.
However, once connected to my vehicle (Fiesta TiVCT, Year 2010) I noticed only PCM & OBDII modules being detected.
Under DTC no faults were listed but ABS & TSC in instrument cluster are lit.
Then in Config & Programming, there is nothing to choose
I noticed it doesn't load / detect BCM module. Is that the reason I cannot change config ?
How about not being able to read active DTC / MIL ?
elec2016
Vehicle: Ford focus
Post by elec2016 » Wed Nov 07, 2018 4:18 pm
Hi, 2017 Ford Focus here. I'm not able to get into central configuration, getting loading sbl failed message. It can't read block 1/6 then says service interrupted. Anyone can help?
From reading other users reporting similar issues, I feel like that Forscan doesn't work well with newer model year cars. Most users reporting similar issues have 2017/2018 cars.
Andyfocus
Post by Andyfocus » Tue Nov 27, 2018 10:18 pm
works fine with mine , fails occasionially but usually completes on 2nd try , ford focus 2017 1l ecoboot <- not a typo
elec2016
Vehicle: Ford focus
Post by elec2016 » Sat Dec 01, 2018 1:01 am
I take back what I said. I was using a Bluetooth one and kept getting that error. After buying a USB scanner and I was able to read the central configuration.
JTECNO
Vehicle: Ford focus 1.6 tdci 2009
Post by JTECNO » Thu Jan 03, 2019 10:08 pm
Good evening I am new and say that today I programmed a complete smacmi bcmii module but I could not make it start by the keys
tiguer22
Vehicle: ford c max
Post by tiguer22 » Sat Feb 23, 2019 8:03 am
hello to all I have a ford c max and I want to add the fog lights in
cornering lights and also the number of
blinking direction indicators eg go to 6 instead of 3 when one
support has put race on the commodo thank you for your answers
nasos73
Vehicle: Fiesta st 1.6 - 182ps - 2017
Post by nasos73 » Mon Mar 11, 2019 1:06 pm
Hello friends.I want your help...After activating my camera ( factory retrofit ) i get the screen below. Is something i have to change in asBuilt? I avtivate it only in IPC menu. Fiesta st 2017 euro with sony 4,2 screen. Please help...Thanks in advance.
https://ibb.co/YbPycd5
pimpalla83
Vehicle: grand marquis, 4.6l, 2009
Post by pimpalla83 » Wed Mar 13, 2019 6:39 pm
hello,
i am new to this and forums in general. i have a 2009 Mercury Grand Marquis. after reviewing some of the tech data on here and trying it out for my self i am at a loss and hoping someone can help. i am trying to disable TPMS and i have downloaded the spreadsheet that one user posted but i am at a loss as to where i can input those binary codes.
any info would be helpful.
thank you in advance
marvas64
Vehicle: Mazda 3 BL, 2.2 MZR-CD, 110kW, 150cc, 2009
Post by marvas64 » Mon Mar 25, 2019 1:45 pm
bretman wrote:
Mon Sep 25, 2017 2:29 am
Does anyone know whether the Mazda 3 BL model (2009-2013) has central configuration?
Its hard to see whether it is used or not.
If I download the as-built configuration from Mazda, there is a CCC section and it does have content. In contrast the BK Mazda 3 does not have this section.
When I access the vehicle with Forscan, however, there is no CCC module visible. (I do have access to both MS-CAN and HS-CAN buses)
Anyone know?
Thanks.
web.b2b.mazda.co.jp/AsBuilt/
https://web.b2b.mazda.co.jp/AsBuilt/Com ... rPage.aspx
*dan*
Vehicle: Focus, Ecoboost 2.3/350PS,2016
Post by *dan* » Sun Mar 31, 2019 3:37 pm
Focus 2016 MK3 5 Door
So had a look through the guide and managed to download the zip file (not from Ford technical as have no access to that) and extracted them to the correct folder.
Again on running the service procedure for the BCM (main) it’s coming up with message..
‘Secondary boot loader file not found error opening file GV6T-14C097-AA.VBF.’
It’s offered to download the file but not sure on that until I know what it’s doing.
