jzchen
Vehicle: C-MAX Energi, 2.0L I-4, Atkinson/188 hp net, 2013
Post by jzchen »
axels74
Vehicle: Ford Focus
Post by axels74 »
I want write something in APIM, but I don't have CC. Existing another version of software?
Missing CC.JPG (30.08 KiB) Viewed 11787 times
Forscan version.JPG (44.39 KiB) Viewed 11787 times
axels74
Vehicle: Ford Focus
Post by axels74 »
fmiki wrote:Good morning!
I tried to use the central configuration on my tourneo custom but i only have this page.
The tourneo custom is not supported yet?
can u pls, tell me, what version of Forscan used it?
My version, don't have posibility to write in APIM.
THNX
chief_bs
Vehicle: F150, 3.5EB, 2015
Using Central Configuration to upgrade from Sync 1 to Sync 3
Post by chief_bs »
I am considering doing this mod on my 2016 Focus MK 3.5. Once I get it installed and run Central Configuration, will it read the new APIM and give me options to activate it? Right now, my current Sync 1 APIM only gives me the options for non-touch. In would much prefer to do it with Central Configuration than to try to individually configure each APIM address. Please let me know. Thanks!
mmoqry
Vehicle: ford/4.6/1999
Post by mmoqry »
R-BCM FOR Mazda 6 2017
7B7-01-01 1D54 0006 E31A
7B7-0102 A504 0380 08F5
7B7-0103 0030 9010 92
I want to Find My Car enabled
hoahongxanh
Vehicle: Ford Ecosport
Post by hoahongxanh »
Thank you so much
dannysun
Vehicle: Ford Focus,Ecoboost GTDI 2.0L,2016
Post by dannysun »
Sir,so sorry to bother u.For i use FORScan not too long ,i'v got a trouble like follows,Please give me a hand,thanks a lot .
When i try to run CC function with the new transit,i meet "Loading SBL To Primary module",file name seems like BK2*-******-**.VBF,and i have got the AB file from Ford ETIS,but i dont known how can i get the VBF file with the AB file or i cant do this.
By the way,i cant see the Function behaviour mode choice on my CC screen,like Normal mode/Engineering mode 1/Engineering mode 2,i dont known why.Look forward to your reply,thanks again.
lskg
Vehicle: Ford Kuga ST-Line 2.0 EcoBlue MHEV 150cv 2021
Central Configuration for EU(IT) Kuga MY2017
Post by lskg »
Hi to all and many thanks to FORScan guys for their amazing work.
I'm a newbie to FORScan, but i use it without problem (good usb obd2 module, 2.3.12 version and now 2.3.13 version with extended license, vbf file, ecc).
I've successfully made some mod on my car APIM to activate Clima Control and ST logo splash screen on Sync 3.
I can read without problem at CC of my car, but what i don't understand is if CC programming in FORScan is fully compatible with my car; I see many parameters with their default values, but i don't know if this parameters and their default/alternative values are correctly mapped for my car.
In another thread and another forum i've read that for my car the only things avalaible for change with FORScan are Clima Control and ST logo (APIM), but i think that if i see the CC programming page in FORScan then i can use it to mod the CC.
Some explanation? (and sorry for my poor english).
Thank you.
gasguzzlers
Vehicle: Ford Kuga 2, 2ltr diesel, 180ps, 2015.
Coding Kuga mk2 2015 Auto doorlocking.
Post by gasguzzlers »
Hi everyone.
I have been a member for a while and have searched and tried various ways to activate autolocking on my Kuga 2 when moving off but until now it has not worked.
I managed to activate it using Foccus software and then clearing down the many faults that this caused in the BCM/PCM/TCM etc with FORscan.
I carry out a lot of coding on various cars but coding my Kuga's BCM with the whole dash shutting down for a couple of minutes and then coming back alive with multiple codes and messages makes your heart miss a beat, even though they have all cleared and reset.
If anyone needs any help coding this feature on their Kuga mk2 let me know. :D
qaraman
Vehicle: optra 2010
Post by qaraman »
that was a very useful post....thanks
Graduated from Soran University with First Class Degree with Honours in Computer Science
