Outformer
Vehicle: 2015 1.6 ti-vct
Post by Outformer » Fri Jun 14, 2019 10:36 pm
hi. How do I turn these two features on my 2017 car?
https://hizliresim.com/7BYZB5
https://hizliresim.com/JVXBWY
maidus
Vehicle: mondeo, 2.0 tdci 163hp, 2011
Post by maidus » Fri Jun 28, 2019 6:49 pm
So, i have recieved my STN2120 cable and was trying to change radio and instrument cluster language from Italian to English in Central Configuration (Main) It did download missing files and all went good, no errors popped up. But, now there are several DTC-s and my climate is acting WEIRD. There is little A/C and all heat comes very early in the temps, like 19celsius it blows pretty hot air.
Please, a little guidance here. Using latest Forscan build. I did run a relearn from that same menu fro PCM and RCM but nothing changed.
===SASM DTC U0140:00-28===
Code: U0140 - Lost Communication With Body Control Module
===ABS DTC U0140:00-08===
===ABS DTC U0126:00-08===
Code: U0126 - Lost Communication With Steering Angle Sensor Module
===ABS DTC U0452:68-48===
Code: U0452 - Invalid Data Received From Restraints Control Module
===ABS DTC P1635:05-08===
Code: P1635 - Tire/Axle Out of Acceptable Range
===HVAC DTC U2101:00-28===
Code: U2101 - Control Module Configuration Incompatible
===RFA DTC U0140:00-08===
===ACM DTC U0140:00-28===
===IPC DTC P1607:87-2A===
Code: P1607 - MIL Output Circuit
===IPC DTC U0140:00-2A===
===IPC DTC U0151:00-2A===
Code: U0151 - Lost Communication With Restraints Control Module
Outformer
Post by Outformer » Tue Jul 09, 2019 6:50 pm
To activate Aux, I need to write 03 to the program that focuses on the picture, I can't write using the forscan program.
https://imgyukle.com/i/kqEpC6
https://imgyukle.com/i/kqEGFy
thebestever025
Vehicle: 2015 ford focus se
Post by thebestever025 » Wed Jul 24, 2019 1:43 am
Anyone try to add more feature to the icp I have a 2015 se . Just trying to get more features like drive modes and police mode on screen. where I can enable it on the fly. Thank you in advance
TimFor
Vehicle: Ford Focus, 1,8 TDCI, 85kW, 2007.
Post by TimFor » Sat Aug 10, 2019 1:37 pm
FORScan wrote:
Thu Jun 09, 2016 11:24 am
Focus Mk2 has no central configuration. Only Mk3/3.5 have one. Please use ElmConfig for Mk2 configuration programming.
This was written in 2016. What's the situation now? Does FORScan cover all of ElmConfig?
Vtprs
Vehicle: Ford Fiesta ST2 2014 180bhp
Post by Vtprs » Tue Aug 20, 2019 9:54 am
notmoby wrote:
Sun Jul 17, 2016 6:58 pm
Happy to report success enabling powerfold mirrors and puddle lights on a mk 7.5 Fiesta. Extended licence and Engineering mode needed in Central Configuration. Good work chaps!
Could you explain how i could do this to my Mk7.5 fiesta ? I have the mirrors and switch fitted how can i programme mine to be able to work ?
Regards
Valter
lollapalooza
Post by lollapalooza » Tue Aug 20, 2019 9:58 am
Eplain how i could do this to my Mk7.5 fiedta ? I have the mirrors and switch fitted how can i programme mine to be able to work ?
Regards
Valter
You just need to select the correct item from the drop down menu.
Check this same thread from the beginning.
Viking88
Vehicle: Focus,EB75926, 1560cc, 2014
Post by Viking88 » Tue Sep 10, 2019 1:06 pm
Hi there new to all of this,
Attempted to enable global windows unsuccessfully and somehow lost my key.
Managed to get key back but now have these errors that wont clear
2014 focus 1.6 navigator TDCi
Viking88
Post by Viking88 » Tue Sep 10, 2019 3:09 pm
Is there anyway to regain original parameters after changing and not saving the original?
Viking88
Post by Viking88 » Fri Sep 13, 2019 5:11 pm
Thanks for the help folks, very much appreciated 🙄
