Outformer
Vehicle: 2015 1.6 ti-vct
Post by Outformer » Fri Jun 14, 2019 10:36 pm
hi. How do I turn these two features on my 2017 car?
https://hizliresim.com/7BYZB5
https://hizliresim.com/JVXBWY
maidus
Vehicle: mondeo, 2.0 tdci 163hp, 2011
Post by maidus » Fri Jun 28, 2019 6:49 pm
So, i have recieved my STN2120 cable and was trying to change radio and instrument cluster language from Italian to English in Central Configuration (Main) It did download missing files and all went good, no errors popped up. But, now there are several DTC-s and my climate is acting WEIRD. There is little A/C and all heat comes very early in the temps, like 19celsius it blows pretty hot air.
Please, a little guidance here. Using latest Forscan build. I did run a relearn from that same menu fro PCM and RCM but nothing changed.
===SASM DTC U0140:00-28===
Code: U0140 - Lost Communication With Body Control Module
===ABS DTC U0140:00-08===
===ABS DTC U0126:00-08===
Code: U0126 - Lost Communication With Steering Angle Sensor Module
===ABS DTC U0452:68-48===
Code: U0452 - Invalid Data Received From Restraints Control Module
===ABS DTC P1635:05-08===
Code: P1635 - Tire/Axle Out of Acceptable Range
===HVAC DTC U2101:00-28===
Code: U2101 - Control Module Configuration Incompatible
===RFA DTC U0140:00-08===
===ACM DTC U0140:00-28===
===IPC DTC P1607:87-2A===
Code: P1607 - MIL Output Circuit
===IPC DTC U0140:00-2A===
===IPC DTC U0151:00-2A===
Code: U0151 - Lost Communication With Restraints Control Module
Outformer
Post by Outformer » Tue Jul 09, 2019 6:50 pm
To activate Aux, I need to write 03 to the program that focuses on the picture, I can't write using the forscan program.
https://imgyukle.com/i/kqEpC6
https://imgyukle.com/i/kqEGFy
