multimen
Vehicle: mondeo mkIV
Post by multimen » Sat Feb 17, 2018 1:40 pm
Hello, I would like to activate Cruise Control in Focus MK3, using Forscan and interface with STN1170 set to 500kbps.
- Can I do it with Forscan or just with Focccus?
-What is the right Baundrate for Forscan?
STN1170 supports 2Mbps in Elmconfig! And it has an automatic switching MS-Can / HS-Can.
I tried Focccus but did not read CCD from BCM, I thought I would not have a VBF file, and people write that it is dangerous.
I've seen that forscan retrieves the VBF file itself when it is connected to the internet.
I tried to change the settings in the central configuration, and after proceduze the cruise control was not active, so I read the CCC configurations again, and the change was not made even though the module was successful, the DTC has a fault in the steering system, mechanical damage, I found out the fault is because I exchanged the bundles, I put the cruise control keys, but I forgot to activate the ASL, is it possible that the BCM did not save the cruise control configuration because it was not modified at the same time as the ASL?
:D
Edit for update : All done !!! ForScan its the best.... ;) only one problem polish translate must by verified in english languidge I see 3 buttons SAVE WRITE and WRITE To BACKUP and first time in polish languidge I klick to wrong button :roll: ..... some budy know it is posibile in cental configuration select engin from 95Hp to 115Hp and change this hors power in engine ???? Or dont doit nothing?? This change. !
Mondeo 2007
Vehicle: ford Mondeo mk4 2007 2,0tdci 130 hk
Post by Mondeo 2007 » Sat Mar 31, 2018 11:43 am
hi, are they someone here to help me get convers + IPC to get in touch with BCM. I changed it to newer. Must be coded or something. Thank you for all the answers.
Mondeo 2007
Post by Mondeo 2007 » Sat Mar 31, 2018 1:47 pm
ivelliosy
Vehicle: Ford Focus, 1.5 TDCI 120HP, 2015
Post by ivelliosy » Tue Apr 03, 2018 5:35 pm
Hello Team!
Yesterday I tried to change <Audible Mislock> byte in my MK3.5 Focus. Value was <unknown> and I tried to change it to <04> like it can be done on FocCcus software. However, it only allows me to inpu <4> instead of <04>. Are they same? Because my intended feature (double honk) doesn't work. And also I had bad memories with FocCcus so I don't want to use that. (Made me reprogram my BCM to dealer)
Thanks!
tshaw8524
Vehicle: Ford edge 2014
Post by tshaw8524 » Sat Apr 21, 2018 11:18 pm
can someone please tell me if there is a way to flip the image on the backup camera right side up using the central config?
Can it be done by changing a bit?
slavekzg
Vehicle: ford smax 2.0tdci 2014
Post by slavekzg » Wed May 30, 2018 3:37 pm
Dear all,
I have s-max 2012, and Im trying to access CC, but it fails to read it. Any clues?
sebasst
Vehicle: Focus 2.0 gdi 2016 170 hp & Ranger 2.2 cs 2017
Post by sebasst » Fri Jun 29, 2018 2:03 am
Hello, I'm using forscan a few days ago and I managed to modify the apim module of my Ford Focus 2016, and leave it configured to work 100%, now I have a question, I also have a Ford Ranger 2017 T6 (2.2 tdci), I want to activate the control cruise and perimeter alarm,with the CC, but do not achieve anything, someone can guide me on my problem, since I thank them very much their attention, and congratulate them for the effort and dedication in this valuable tool ..
shevchukw
Vehicle: 2017 f150 2.7
Post by shevchukw » Thu Jul 12, 2018 3:46 am
i have 2.3.15 and i cant get to the screen where it gives you option to change engineering 1 or 2 etc. i need to remove MYKEY to remove my speed limiter. i know its under option in BCM 720-02-01 but i can only access starting 726-xx-xx. i do the the extended licence also. how do i get here???
2015 f-150 3.5 ecoboost
silverwings
Vehicle: Mondeo Mk5
Post by silverwings » Wed Sep 19, 2018 6:02 am
Hi, will this Central Config work on a 2017 Mk5 Mondeo? Thanks
davetcollection
Vehicle: Focus '17 ST-Line 1.0 Auto, Focus 4 1.5D Titanium
Post by davetcollection » Mon Sep 24, 2018 9:43 am
Does anybody have any knowledge of activating AUTO LOCK on new Fiesta (MK8) 2017 on
It only shows BdyCM (ASBUILT) and there is no CC.
When you go into the module it's just a list of config codes (720-01 etc etc)
Does anybody have the "crack" for each of the functions of these codes (a bit like changing the splash screen on Syn3 to ST etc etc)
Any help would be greatly appreciated
