Head lamp timer when truck is off
metalfab12
Vehicle: F150, 3.0 Diesel, 2018
Post by metalfab12 »
Is there an adjustment to the delay of the headlamps once truck is off and doors are locked? It takes 15-20 minutes for the headlamps of my 2020 F150 to turn off. The only programming I have done is bambi mode. (Halogen lamps)
omar302
Re: Head lamp timer when truck is off
Post by omar302 »
The 15-20 minutes you are seeing should be the battery saver kicking in. There is no adjustment to that, as far as I know. But, if you have "Autolamps", there should be a setting in the instrument cluster "Autolamp delay", this setting will keep headlight on for the set period if the light switch was left in "auto".
