Dual zone aircon change sides
Brayden1945
Vehicle: Ford Mondeo 2.0 TD 2017
Post by Brayden1945 »
Hey all, first post on the forum here
Just have a quick question
On my ford mondeo mk5, ​I updated from sync 3 V2.3 to the new 3.4 via cyan labs.
Since that update the dual zone aircon in the car hasn't been functioning correctly. Usually when I change the drivers side temperature it will change both sides when dual zone is turned off, but now it will only change both sides if I use the passenger side temperature button instead of drivers side. It's very annoying as whenever I now change the drivers side temperature it will now turn on dual zone and only change the drivers side and not the passenger side aswell.
I'm under the impression because when I chose the sync region which was USA/ all other parts of the world. It now thinks the drivers side is on the left side of the car, even though in Australia it's on the right.
Is there any possible way to change this in forscan? Such as which side the car thinks is the driver's side in regards to the aircon?
