Stock TCM for 2019 transit custom 170ps auto
mark.brameld
Vehicle: Transit custom diesel 130ps 2019 crew cab with tailgate
Post by mark.brameld »
Hi all
I’m looking for an asbuilt / stock TCM from a 170ps transit custom auto 2019. I have the 130 but changed the setting to make it 170 and it’s definitely quicker but I need the TCM file/settings for the 170ps as I believe I need to change it.
Mark
Re: Stock TCM for 2019 transit custom 170ps auto
Find one of those models that is 170ps with automatic transmission.
Look for a "seller" or used vehicle department.
Find the VIN and use it to find the data.
The problem is that the exact transmission type needs to be matched.
Instead of that, reset the learned values with FORScan and perform the correct adaptation with the road test.
mark.brameld
@Ecmbuster
Thanks for your reply,
Could you explain how I do
"Instead of that, reset the learned values with FORScan and perform the correct adaptation with the road test."
I'm still learning forscan (step learning curve)
Do you know if the TCM values need changing? After changing the engine type from the 130 to 170.
Mark
You need to post images of the initial scan, faults and strategies.
Images include what is in view in the Modules Tab.
You also need to post the transmission version in your model
Is it 6-speed automatic transmission? What model is it?
Ford etis can provide the needed details.
