PCM Configuration to Show Current Gear?
omar302
Post by omar302 »
@FORScan
Hi, can the PCM configuration allow to always show the current gear in the IPC at all times? I have a 2016 Ford Edge (NA) and the PCM configuration only shows the Active Torque Coupling configuration. Noticed in this Post (viewtopic.php?f=16&t=18722) that a member with a 2017 Edge (EU) has more options in the PCM Module Configuration including "Shift Indication".
