au falcon no as built data in forscan
crickeymate11
Vehicle: ford falcon 6cyl 4L 1999
Post by crickeymate11 »
anyone tried to bring up asbuilt data on an au ford falcon ( australian car)
My au is 1999 model.
Tried to see asbuilt data in config section but nothing showing.
I am using obdlink usb type and latest forscan windows version.
so ms/hs switch not needed I assume since using obdlink brand.
I'm wondering if forscan has overlooked this vehicle model?
I note there are some options on the general connection section of forscan would any of those options be useful to try?
Maybe I should update firmware on the obdlink device as a message came up saying its not latest firmware version
general connection.jpg (162.13 KiB) Viewed 66 times
forscan config programming.jpg (127.28 KiB) Viewed 66 times
Re: au falcon no as built data in forscan
You have the incorrect setup. OBDLink is not a J2534 device.
Apply the correct USB settings with the correct drivers.
"obdlink usb type" is that the OBDLink EX?
Make sure the firmware is updated.
Choose the correct setup at "Connection Type"
Don't be surprised how little that model has with As-Built data.
Post your results.
