Ford Transit 2015 no mileage in cluster & language change
Chris AGR
Vehicle: Focus II 1.6 109hp 2008
Post by Chris AGR »
Hi again.....
I don't know if this the right section...
I have a Ford transit 2015 EU, and didn't show mileage in clusters lcd, i check the menu but no option for mileage....
Only if i move in test menu i can see the mileage....
Is it possible the dashboard don't show the car mileage?
(In this car they had tachograph before...)
And I can't find menu to change the language, now is in France and i want to set it to English...
Any one can help?
Re: Ford Transit 2015 no mileage in cluster & language change
1) Post the entire scan image
2) Post the fault codes recorded image
3) Post the image at the Modules Tab
The PCM or BCM may record the exact mileage and display that group.
Was the Instrument Cluster tampered with?
Seen that many times.
Chris AGR
Post by Chris AGR »
Sorry for the delay....
here is a full scan from car..... i didn't see IPC..... but cluster works fine....
Vehicle:
Model: Ford Transit / Tourneo Custom
Engine: Duratorq Turbo Diesel Common Rail Injection
Capacity: 2.2L
Year: 2015
Month: 09
Generation: 2012.75MY
VIN: WF0YXXTTGYFJ63680
PCM - Powertrain Control Module
Part number: BK21-12A650-AC (latest known: BK21-12A650-BRX)
Strategy : BK21-14C204-BRR
Calibration: -
Hardware type: SID-208
Total Distance: 113344.0 km
APIM - Accessory Protocol Interface Module
Part number: D1BT-14D212-LA (latest known: D1BT-14D212-RB)
Strategy : E1BT-14D205-AG
SASM - Steering Angle Sensor Module
Part number: BK2T-3F818-AD (latest known: BK2T-3F818-AF)
Strategy : DV6T-14C309-AB
ABS - Antilock braking system
Part number: EK21-2C405-AA
Strategy : EK21-14C036-AA
RCM - Restraint Control Module
Part number: BK2T-14B321-AG
Strategy : BK2T-14C028-BA
Calibration: BK2T-14C098-AG
HCM - Headlamp Control Module
Part number: BK21-13C148-AB
Strategy : BK21-14D063-AA
BCMii - Body Control Module
Part number: BK2T-14B476-BU (latest known: BK2T-14B476-BZ)
Strategy : BK2T-14C184-AS
Calibration: BK2T-14C185-AS
and in cluster menu i have only this two options....
Chris AGR
Post by Chris AGR »
no any info about that problem?
is anything i can do by BCMii? can i check if instrument is programming correctly there?
Ghano38
Vehicle: Ford c max
Post by Ghano38 »
Ça ne s'affiche pas tout simplement parce l'adaptateur utilisé ne prends pas en charge le réseau ms can apparemment,a tu essayé de faire une mise à jour ou c'est arrivé du jour au lendemain ?
Il se peut que le micro logiciel soit incomplet.
It just doesn't show up because the adapter used doesn't support the ms can network apparently, did you try to update or did it happen overnight?
The firmware may be incomplete
