WEIRD ABS FAULTS FOCUS MK3 1.0 ECOBOOST
0ford
Vehicle: Focus 1.0 ecoboost 2015 123bhp
Post by 0ford »
Can anyone help solve these faults on a UK 2015 Ford Focus 1.0 ecoboost?
The faults on Forscan are:
B10DF:46-2B - Master Cylinder Isolation Valve
Additional fault symptom: - Calibration/Parameter Memory Failure
U2007:46-2B - Valve(s)
Additional fault symptom: - Calibration/ Parameter Memory Failure
It says the malfunction indicator lamp is off for both of these faults on Forscan but the traction control light is on permanently on the dash.
Any help will be much appreciated thanks.
Re: WEIRD ABS FAULTS FOCUS MK3 1.0 ECOBOOST
B10DF:46-2B
The control module indicates a calibration / parameter memory failure for embedded systems using FLASH memory.
U2007:46-2B
This fault can be regarded as a communications fault.
What changes did you make prior to this fault and did you replace any components?
If no changes were made or no components replaced, it appears to indicate the ABS control module is internally defective.
If a new one is purchased, it will need to be programmed because they have no software loaded.
