enable Fiesta MK8 180 degree rear view (split view) camera SYNC 3.4
neolec2001
Vehicle: Focus MK4 ST 2.3 -- Fiesta MK8 1.0 Ecoboost
Post by neolec2001 »
Hello Together,
is it possible to enable afterwards the 180 degree view mode? (Fiesta Titanium MK8)
I have this view in my Focus MK4 and would like to add this feature to our Fiesta.
The fiesta is not equipped with the dead angle sensor
BR
CommaL
Vehicle: Ford Fiesta 2018 1.5 Dizel
Re: enable Fiesta MK8 180 degree rear view (split view) camera SYNC 3.4
Post by CommaL »
as far as i know it works with sync 2.5
CoD21
Vehicle: Ford Fiesta MK8
Post by CoD21 »
Maybe the Focus-Camera is required for that?
neolec2001
This evenig I get the Fiesta back and then I will check with FORscan what is possible.
I found also out, that a different camera is available
New Version:
L1BT-19G490-AA
Old Version:
H1BT-19G490-AE
On my Focus, the FORscan otpion for split view is set.
The dealer said today, he *think* it is just a software setting to enable it.
I'll keep you updated.
neolec2001
I got the Fiesta back and tried to interchange the cameras between the Focus and the Fiesta.
This is impossible, the Focus camera cannot fit into the placeholder for the Fiesta camera because it it sligthly bigger than the one from the Fiesta.
So the Focus camera is not the key.
I also tried to set the option for SplitView to true, but this also dont work, even the SplitView button was not shown.
Maybe this is triggerd by the hardware of the camera.
I'll try to get one of the newer cameras and report back.
Ghano38
Vehicle: Ford c max
Post by Ghano38 »
Dos your Fiesta have front,rear pdc and active park assist?
neolec2001
Yes it have all those options. But no dead angle sensor. (Focus have it)
CoD21
Post by CoD21 »
neolec2001 wrote:
Thu Jun 17, 2021 6:40 pm
He is talking about the rear Camera, Not the front Camera!
Ghano38
Vehicle: Ford c max
Post by Ghano38 »
It's a rear view camera module non compatibility issue it explains why it's not working in the Fiesta since both cars have the same Sync system with the feature activated in both of them so you need the appropriate module.
neolec2001
I ordered now the newer version of the camera, I'll keep you updated.
