Aftermarket APIM, not working volume buttons
Keithmac
Re: Aftermarket APIM, not working volume buttons
Post by Keithmac »
It could be hardware incompatible, is the new APIM from the same model and model year?.
Balage wrote:
Wed Jun 16, 2021 5:15 pm
I tried everything, if the original file load, the APIM first startup no navigation, and still not working the buttons under the screen,the touch screen buttons working, if change the 7D0-01-02 x4xx xxxx xx, the navigation and climate icons get back and touchscreen buttons ok, but buttons indre the screen still not work.
thanks
if you installed a new APIM module, the battery cable was disconnected before :?:
see pm :!:
Graham17
Post by Graham17 »
Thanks for reply.
I Have always used cyanlabs.net for asbuilt codes for APIM, always been spot on. I understood BCM needed to tell APIM that car was in reverse as no direct connection other then camera. I have tried powering mine both ways 12v ign controlled 12v and from reverse lights. Neither works. On Fiesta mk8 identical kit, if camera not in circuit you got a blank screen when reverse selected. The Focus doesnt change at all when reverse us selected
smartguy69
Post by smartguy69 »
@balage - are we talking about sync 2 or 3. I had assumed sync 2 but on close checking I see you have a 2018 vehicle.
@Graham17 - I think you have posted in the wrong thread.
Graham17
Post by Graham17 »
Oops yes sorry! i have, i will remove it if i can
Tried to remove, but just tells me not enough text, when i delete.
Balage
Vehicle: Ford Tourneo Custom 2018 2.0 Tdci 170LE
Post by Balage »
@Smartguy69
The car is facelift model with sync3.
