Daytime lamps?
brummiejim
Vehicle: Transit 2012 125
Daytime lamps?
Post by brummiejim »
Novice question maybe....
I wanted to switch off my daytime running lights.
First time I’ve had a go at this, I read all the info and did the job (I think) 👍
My only question is that I thought there would be an option for ‘none’
The only option I thought suitable from the displayed list was ‘not configured’
Everything seems to work so far.
I noticed the in body control I get a fault now (wasn’t there before) I’m guessing here my choice of setting is to blame?
Anybody else had this issue? Nothing seems wrong on the van.
It’s a 2012 swb standard 2.2
Cheers,
Jim
Re: Daytime lamps?
You're in the Euro zone? Canada, Australia?
Why disable the DRL system?
If you are, that model is adapted for Day Time Running Lights.
Post a screen image of the fault at the BCM out of curiosity.
Reset / adapt the original function and test again.
Post your results and image.
brummiejim
Re: Daytime lamps?
I’m in the uk.
I just wanted the lights to operate normally, I’ve never been a fan of daytime lamps to be honest.
I’ll check as soon as I can.
Thanks for the info/help.
Cheers,
Jim
