Ford transit connect 2015 v408
lynchmeister76
Vehicle: Transit connect 408
Post by lynchmeister76 »
Hello , I'm new to forscan started using yesterday.
My issue is my steering is consistantly trying to adjust itself.
The angle of PSCM is 5773.50 all the time. SASM is working perfect.
I believe this is probably not easy to fix , but I'm wondering if I change dynamic vehicle control to abs , the modules won't over compensate.
Can I make my van simpler to control ?
Re: Ford transit connect 2015 v408
Can you post the entire scan data with ALL fault codes and what did you do to this model?
Did you replace any parts? Was it involved in a road accident?
What did you change or write to a control module?
lynchmeister76
Hey ,I've no fault codes . I had concerns about steering and that's why I started to use forscan lite on Android.
That's when I noticed the pscm SW angle doesn't change.
All I've done with forscan PC is set locks to autlock at speed and turn off the unlock button when the vehicle is locked.
I had changed a lot of other things and got several errors and then had to back track. I'm taking photos of change screens before I write any changes.
In the programming screen on forscan PC in the pscm , all I have is one line of code.
I had a battery go completely flat few months back and I think that was the start of the trouble, maybe a file got corrupted or sensor got damaged when I was jumped.
lynchmeister76
This morning I changed dynamic vehicle control setting to abs and the steering is now so lively/natural.
I will try and get an auto specialist to fix the pscm angle sensor when I have time , but at least for now the weight is literally off my shoulders.
Ask the moderators to merge these posts.
viewtopic.php?f=6&t=18663&p=66763#p66763
