Decoding of the radio from the USA to the EU Mazda CX-7
Eryk
Vehicle: Mazda CX-7 2,3 DISI TURBO 244KM
Post by Eryk »
Hello everyone.
Maybe some of your colleagues know how you can reprogram the US version of the radio to the EU using Forscan? The car is Mazda CX-7 year 2007 2.3T 244KM petrol.
I know that in the Mustang from 2012 you can do this (In the ACM module, find the value 727 04 01 (not like the above 727 01 04 - this value does not exist. In my case, in the Mustang with 12, the ACM value was as follows: 727 04 01 0033. After changing to 727 04 01 0134, the radio will reset and we will see even frequencies. End).
Re: Decoding of the radio from the USA to the EU Mazda CX-7
Post the entire scan and VIN of that model.
Post the radio part number.
Eryk
Post by Eryk »
Radio:
- model no. - 14795010
- part no. - EG26 66 DV0A
- serial no. - 06F1B0883305
- SANYO
VIN - JM3ER293X7012882
The tuner modules are different between the US and EU Mazda models.
It may be possible to install the Euro firmware. That will depend on extra features like SAT and NAV.
Another method is to have an identical radio and save its internal flash and then transfer the Euro flash to the radio.
Call the local dealer and ask if a flash is available for that conversion.
FORScan is not capable of that type of flash update.
Eryk
Post by Eryk »
Thank you.
