Fiesta MK8: Activate PTC heater?
Dragunov
Post by Dragunov »
I wonder where to activate the PTC heater?
Thanks!
Re: Fiesta MK8: Activate PTC heater?
Did you install the system? Did you change any data?
Was it installed from the factory?
Did you replace a control unit?
Do you have a control module list? Do you have fault codes recorded on the network?
Dragunov
Post by Dragunov »
Everything was prepared (cable), just had to add the PTC heater, but I wonder where to activate it?
powertrain352
Vehicle: Fiesta 1.0L Ecoboost MK8
Post by powertrain352 »
Dragunov wrote:
Fri May 14, 2021 7:02 pm
Is the PTC heater to heat the seats? Check the HVAC module. If you don't have a physical button for that things might get tricky.
consp
Vehicle: Fiesta 125hp 2017 (My13.25 Mk7.5, With EU Sync3)
Post by consp »
powertrain352 wrote:
Thu May 20, 2021 8:41 pm
PTC heaters usually are used to pre-heat the air for the cabin if the engine is not warm enough. Early Mk7/Mk7.5 models came with one as the engine was not hot enough quickly (especially the diesels). Don't know about the Mk8 though. On the Mk7/7.5 it's enabled by setting the PTC heater in the IPC/BCM main configuration.
apollogary
Vehicle: mondeo 2.0 tdci 2008
Post by apollogary »
it's run from the HVAC module. So the code for it is in there somewhere. No idea which bit though. You'd have to make some comparisons.
Unlike some other Fords where it's CAN controlled, the Fiesta has 2 relays which power it and just get signals from the HVAC module to power them. I think one relay runs half power the other full power or something like that
