02 Lightning gear change
rjdboss94
Vehicle: Ford F150 5.4Litre 300HP 2004
Post by rjdboss94 »
I have a friend with 02 Lightning and he has changed his rear gear to 4.10. We are trying to make changes to to the GEM module to update it but are not having luck. Any ideas. THX
Lethal51!
Vehicle: Mustang 4.6L/V8, 2007
Re: 02 Lightning gear change
Post by Lethal51! »
I just did the same on a 2007 GT any help is greatly appreciated
It may not even work and if a change was accomplished, the PCM not going to behave correctly because of the inherited speed signal and ratio change.
Two choices:
Have Ford re-flash the correct ratio into the PCM
Have a "performance" programmer tweak the speed input.
