Lincoln continental rear sundshade
][No_WaY
Vehicle: ford flex 2013 LTD AWD
Post by ][No_WaY »
I have Lincoln continental black label 2018 and I want to stop rear sunshade from automatic drop down on reverse or at least to automatic up again when shift from R to D , any idea how to achieve this?
][No_WaY
Re: Lincoln continental rear sundshade
Post by ][No_WaY »
any idea?
][No_WaY
Post by ][No_WaY »
Up
omar302
Post by omar302 »
This was never brought up before. I don't think there are enough DIY Continental owners who want to change things in the cars. For the Lincoln MKS & Ford Taurus that also had a rear sunshade, the only way to disable the auto down in reverse was to disconnect/cut a wire that goes into the rear sunshade module. The module is connected to the sunshade itself. The Continental is a completely different vehicle, so it will probably be different than the MKS/Taurus.
][No_WaY
Post by ][No_WaY »
omar302 wrote:
Thu Apr 15, 2021 11:23 am
Thanks for your reply, I hope to find any one with generic spread sheet for that so ican test it
][No_WaY
Post by ][No_WaY »
any one got any update ?
][No_WaY wrote:
Wed Jun 09, 2021 7:34 am
Is there a special procedure or note in the operators manual?
There is something odd about dropping a sun shade in reverse.
Did you happen to ask the dealer if this is normal or an optional activation?
][No_WaY
Post by ][No_WaY »
Ecmbuster wrote:
Thu Jun 10, 2021 1:20 am
Actually it mentioned in user manual
( A control is on the overhead console and on the rear seat armrest bezel. Press and release the control to open or close the sun shade. To stop motion and return the sun shade to its previous position, press the control a second time. The sun shade automatically retracts when you shift the transmission into reverse (R) )
