IPMA Firmware Feature Upgrade
elpamyelhsa
Vehicle: Ford Ranger XLT MY17 PX2 w/Tech Pack
Post by elpamyelhsa »
Does anyone know if it is possible to udpate the firmware on a IPMA to allow a feature set change from AHBC/LA to AHBC/LA/TSR
EDIT: Yes it can, see post below post
Currently trying to enable the TSR gives the "Invalid Config" error
My current mirror is stamped with the features AHBC/LA with the below firmware
Part: FU5A-17E678-LG
Hardware: EB3T-14G025-AB
SBL: DA5T-14G021-BA
Strategy: FT4T-14G019-HE
Strategy: FT4T-14G082-HE
ECU/Base: EB3T-14G024-AF
ECU/Personal: FT4T-14G081-HE
Can anyone with a FU5A-17E678-xx mirror stamped with TSR post their fimeware list so I can give this a try? My guess would be the JE to KF or NH mirrors might have compatible formware for mine.
Code: Select all
AHBC = Auto High Beam Control
LA = Lane Assist
IR = ??Not Sure
TSR = Traffic Sign Recognition
AUTODIM = No Camera, Just an auto tinting mirror
FU5A-17E678-AE	AHBC/LA
FU5A-17E678-AG	AHBC?
FU5A-17E678-BC	??IR
FU5A-17E678-CE
FU5A-17E678-DG
FU5A-17E678-DH       AHBC/LA
FU5A-17E678-EA	AUTODIM
FU5A-17E678-JE	AHBC/LA/TSR
FU5A 17E678 JF 	AHBC/LA/TSR
FU5A-17E678-KE	AHBC/LA/TSR
FU5A-17E678-KF	AHBC/LA/TSR
FU5A-17E678-KG
FU5A-17E678-LD	?AHBC/LA
FU5A-17E678-LG 	AHBC/LA
FU5A-17E678-LJ 	AHBC/LA
FU5A-17E678-NH	AHBC/LA/TSR
FU5A-17E678-PF	AHBC/LA/RF
FU5A-17E678-RF	AHBC/LA/RF
FU5A-17E678-SD	AHBC/LA
FU5A-17E678-SE
FU5A-17E678-SF	AHBC/LA/RF	USED FOR TSR
FU5A-17E678-SG
FU5A-17E678-SH
FU5A-17E678-TA	AUTODIM
FU5A-17E678-TB	AUTODIM
FU5A-17E678-TC	AUTODIM
FU5A-17E678 TD	AUTODIM
FU5A-17E678-UA	AUTODIM
FU5A-17E678 VA	AUTODIM
FU5A-17E678-VC	AUTODIM
AU5A-17E678-AC	AUTODIM
BU5A-17E678-LA
CU5A-17E678-BB
DU5A-17E678-AJ	AHBC
DU5A-17E678-EL	TSR?MAYBE
DU5A-17E678-HA
DU5Z-17700-V	LKA
EU5A-17E678-GD	AHBC
GU5A-17E678-CC	AHBC
GU5A-17E678-RA	AHBC/LA/RF
MoJo88
Vehicle: Mondeo Vignale 210ps 2017
Re: IPMA Firmware Feature Upgrade
Post by MoJo88 »
From what I can remember -Sx works well. But if you have a VIN for me I can pull the relevant info for you.
elpamyelhsa
I would like to try flashing the following vbf, can anyone help me find a download for these?
DS7T-14G019-EJ
DS7T-14G024-EF
MoJo88
Post by MoJo88 »
Attached. -EF not valid (or available).
DS7T-14G019-EJ.zip
(293.44 KiB) Downloaded 25 times
DS7T-14G024-EF.zip
(36.58 KiB) Downloaded 17 times
MoJo88
Post by MoJo88 »
Sorry, I mistyped. Now attached.
DS7T-14G024-EF.zip
(36.58 KiB) Downloaded 20 times
two seconds before :)
MoJo88
Post by MoJo88 »
:) I didn't even see your post, lol.
elpamyelhsa
Thanks everyone, can confirm a mirror with AHBC/LA can be upgraded to support AHBC/LA/TSR, its now all working now with the following.
|SBL: DA5T-14G021-BA | NO CHANGE | DA5T-14G021-BA |
|Strategy: FT4T-14G019-HE | UPDATED| FS7T-14G019-SF|
|Strategy: FT4T-14G082-HE | NO CHANGE| FT4T-14G082-HE |
|ECU/Base: EB3T-14G024-AF | UPDATED| FS7T-14G024-SE |
|ECU/Personal: FT4T-14G081-HE | NO CHANGE|FT4T-14G081-HE |
When upgrading, just upgrade the 14G019 and 14G024, and not the other huge updates that take an hour.
If anyone is missing the IPMA Easy Mode configuration, it has been added for the Ranger P375 in FORScan 2.3.39beta
FS7T-14G024-SE.zip
(36.61 KiB) Downloaded 48 times
FS7T-14G019-SF.zip
(295.35 KiB) Downloaded 31 times
Pejcinoski
Vehicle: ford ranger 2015 3.2
Post by Pejcinoski »
Can anyone explain how do we update the modules?
