Upgraded to sync3 - missing charge settings and power flow
innspiron
Vehicle: Ford Fusion 2016 PHEW
Post by innspiron »
I have upgraded my ford fusion 2016 energi plugin (phev) frm sync2 to sync3. Hardware replaced, but now apim is missing app power flow and charge settings. Looked all over the web, but cannot find what settings should be modified via forscan?
In apim module configuration I see no option for charge settings. And in asbuild format I dont know what needs to be modified.
Ghano38
Vehicle: Ford c max
Re: Upgraded to sync3 - missing charge settings and power flow
Post by Ghano38 »
Whatof Forscan(free or paid) and Sync versions are you using ?
innspiron
Post by innspiron »
Forscan says extended license 2.3.24. Sync3 is 3.3 version. My plan is to upgrade to 3.4 but first I wanted to fix those missing settings issues, then I will start with 3.4
MoJo88
Vehicle: Mondeo Vignale 210ps 2017
Post by MoJo88 »
Try this:
7D0-01-02:
Xxxx xxxx xx
Add 2 to the existing value of X. So if it's 0 then change to 2. If it's 1 then change to 3.
innspiron
Post by innspiron »
Thank you a lot. Now I have this half image flow (see pic). But no charge settings, it is more important than power flow.
MoJo88
Post by MoJo88 »
I think the words you are looking for are "Thanks, now I have Power Flow but I still don't have charge settings".
MoJo88
Post by MoJo88 »
Now try:
7D0-01-02
xxxx xxXx xx
Change X from 0 to 8.
Report back and please show some gratitude to those that go out of their way to help you. Hopefully this setting should work for you.
innspiron
Post by innspiron »
Of course I am grateful and my appologies if I sounded not polite :(
innspiron
Post by innspiron »
I am afraid, but last modifications you suggested did not help, now I can see lincoln connect app :| Maybe you know where I can download full asbuild format file to load after the upgrade? Because I see I still missing heated seats icons. Or maybe there is a document explaining all those number meanings in xxx xxxx xxxx? Thanks a lot.
MoJo88
Post by MoJo88 »
Save your asbuilt in forscan and send it to me.
