FORScan v2.4.1 release notes
scanforupdates
Vehicle: Ford Focus Titanium 1.0 92 kW/125 PK 2018
Re: FORScan v2.4.1 release notes
Post by scanforupdates » Thu Sep 03, 2020 1:31 pm
After i updated the PCM firmware, the fuel gage says the tank is empty(0).
Is there something i need to do after the firmware upgrade? DTC gives no errors.
DNH
Vehicle: Ford Focus ST MK3.5
Post by DNH » Thu Sep 03, 2020 1:35 pm
Unplug the battery for a short time and reconnect it. The fuel gauge should work afterwards.
scanforupdates
Post by scanforupdates » Thu Sep 03, 2020 4:18 pm
Thank you. Your advise solved the problem.
fcoplo
Vehicle: Ford Ecosport SE MY2018 1.5 Gas AT6 (Brazil)
Post by fcoplo » Fri Sep 04, 2020 12:07 pm
Hi, this tools could be used to update APIM firmware? There are any documents with steps?
For now just for research and learning, I am not going to upd my apim.
R
scanforupdates
Post by scanforupdates » Fri Sep 04, 2020 3:04 pm
I have ypdated almost every module. With a ODBLinkEx(newest firmware) it took max 5min per module.
R
omar302
Post by omar302 » Fri Sep 04, 2020 3:13 pm
R
What modules & what is your car? Just so we have known successful examples.
rich935
Vehicle: Ford Focus SE 2.0
Post by rich935 » Fri Sep 04, 2020 11:40 pm
I was wondering if you try to update a module for example the TCM or PCM if your computer gets disconnected or a power failure or something like that what would happen? Would you be able to restart the module update or would the module be bricked and unusable. Or something else. If you know please post a response. Thanks.
rich935
Post by rich935 » Sat Sep 05, 2020 2:37 pm
Does anyone know if it is okay to update TCM module only? And not the PCM also.
rich935
Post by rich935 » Sat Sep 05, 2020 10:54 pm
"Unfortunately this site doesn’t contain all the files, also old files seem to be removed. If file is missing here, FORScan requests the file from an independent storage. Access to the storage is only available for users who have paid Extended License.
The independent storage may also have no some files. In this case please contact us and we will try to find it. No guarantee we will be able to do it, though."
Hopefully in newer versions you won't need to have a paid Extended License to do this.
zivnic
Vehicle: Ford Focus MK3
Post by zivnic » Sun Sep 06, 2020 4:58 am
Hi, can I ask you if module updates works also for Focus MK4? I would like to update firmware in IPC module. Thank you.
