How to enable rear view camera sync 2.5 without APIM and FCDIM module?
f9_
Vehicle: ranger 2012
Post by f9_ »
How to
box13GR
Vehicle: ford fiesta mk8 1.0 125ps
Re: How to enable rear view camera sync 2.5 without APIM and FCDIM module?
Post by box13GR »
Hi friend, you might be lucky.After i have been searching for months yesterday i took on the project on installing backup camera on sync 2.5. In latest forscan you will find in ACM rear view camera or something like that. Enable it and see if you get a black screen when you reverse now. If yes report back and i will tell you the rest.
f9_
Post by f9_ »
box13GR
Post by box13GR »
Not in ACM (AS BUILT), in regular ACM, you will find rear view camera.
f9_
Post by f9_ »
box13GR wrote:
Wed Aug 26, 2020 11:07 am
no have regular ACM
box13GR
Post by box13GR »
Are you sure its sync 2.5? What car is that? Check PAM module for camera option.
f9_
Post by f9_ »
box13GR wrote:
Fri Aug 28, 2020 11:22 am
Probably because I using FORScan version 2.3.33?
redrum666
Vehicle: Ford Kuga 2016
Post by redrum666 »
could you solve it?
fcoplo
Vehicle: Ford Ecosport SE MY2018 1.5 Gas AT6 (Brazil)
Post by fcoplo »
box13GR wrote:
Tue Aug 25, 2020 5:08 pm
Hi, could you share please the rest of the story, I want to connect rear camera to sync 2.5.
As far understood, step 1 activate rear camera on acm module to get video signal when rear is activated and step 2 wire the video to the acm module ? and just that?
bdycm module need configuration changes? Thanks
fcoplo
Post by fcoplo »
any?
