How to use FORScan to adjust fuel tank size and DTE
AS-Nitro
Vehicle: Mazda BT50, turbo diesel, 3.2L, 2011
Re: How to use FORScan to adjust fuel tank size and DTE
Post by AS-Nitro »
Is this the same for a 2018 MAZDA BT 50. I followed the steps however IPC Model configuration didn't show up only model configuration as Built Format, Please Help.
denlewis7
Vehicle: F150 Lariat 5.0L Flex Fuel 2020
Post by denlewis7 »
Does anyone know if there is a way to see how many gallons remain instead of DTE or in conjunction with DTE?
mdube
Vehicle: F250, 7.3 Diesel, 2003
Post by mdube »
I don't see ICP as an option on my 2003 f250 7.3. Is there a different process for the older models?
Seahunt
Vehicle: F150 2.7-liter EcoBoost 2018
Post by Seahunt »
I just complete this on my 2018 F150 2.7 .Changed 24 gal to 36. Thank You...
ace_boy2786
Vehicle: 2005 ford f350 6.0 diesel
Post by ace_boy2786 »
mdube wrote:
Thu Feb 04, 2021 5:24 pm
Unfortunately, You are in the same boat as me, It appears that this function/feature is only in the 2008 and newer trucks. Our "Old" trucks (Mine is a 2005 King Ranch) apparently don't have the module that can be changed for this. I'm sure it is somewhere, The computer has to have the calculation somewhere, I just don't know where and haven't heard of anyone finding it to change it. If anyone does find it, though, please kindly let me know.
New user using dell Windows7 pro laptop and Rotunda (Ford/Bosch) VCM-II
1999 F150 4.6 v8 Lariat
2005 F350 6.0 v8 King Ranch Diesel
2006 Ford Ranger 3.0 v6 (Brothers)
2017 Transit T350 3.7 v6 (Parents)
Power guy
Vehicle: F250 6.7 diesel 2017
Post by Power guy »
I have a 2017 F-250 6.7 diesel superduty. I have replaced my stock fuel tank with a larger fuel tank and would like to change the codes on the truck to read the new fuel tank. I was told to find the IPC Module configuration but only see PDM. am i not doing something correctly?
coilylux
Vehicle: 2012 Mazda BT50
Post by coilylux »
AS-Nitro wrote:
Sat Jan 23, 2021 10:24 pm
ive got a 2012 and wanted to do this also, from what ive readed on another forum it isnt possable to change on the BT's for some reason
RSWRC
Vehicle: Ford S-Max 2.0Ecoblue 110kw m.y.2019
Post by RSWRC »
Hello, for the Ford S-max / mondeo / galaxy the range of max is 999km. Even though I actually drive for example 1100km. Can the display be expanded by 4 numbers? And not at 3?
Some cars can do it, but I've seen that they have a different version of SW.
Thank you :) ;)
sipp81
Vehicle: F150 5.0 v8 2021
Post by sipp81 »
Seahunt wrote:
Sat Feb 13, 2021 1:53 pm
how did you do it..I get errors during the process about making sure the vehicle is not in motion
Gripper76
Vehicle: F150, 2.7 eco boost, 2019
Post by Gripper76 »
Hi, VERY new here but WHY are people changing the tank size? is it wrong from factory?? I have a 2.7 F-150 also.... Thanks :)
