Have the rear lights on at the same time as DRL
Gustas_J
Vehicle: Fiesta Titanium, 1.0 Ecoboost 100hp, 2013
Post by Gustas_J » Mon Jul 13, 2020 11:17 pm
Hello there!
I have a member in a danish fiesta group that wishes to have the rear lights to be on while DRL are on. So I decided to start looking around and seems like it is possible! But I'd like to doublecheck with someone that actually has some experience doing stuff like this :D
The car is a ford fiesta Vignale mk8 from 2019 EU running sync 3.4.
I've done some research and according to the user "Salva" he has done it!
He writes that:
"in ipc 720-02-01 xx(6)x xxxx xxxx add 4 at your value, I had 2 and i put 6 : with this you have menu option in small screen to enable or disable DRL
in bcm 726-11-04 xxxx xxx(5) xxxx add 4 at your value, i had 1 and i put 5 : with this you enable park lamps rear and front drl"
This I do understand and I think I could handle, but this member also had another request. He was wondering if you could keep the RS theme even after shutting the car down and starting it up again. Now this I do not understand. Which values do I need to change? It seems like there are several changes that need to be made here. On startup, in menu and while shutting down?
Hope someone can help me out and thanks in advance!
Original post to DRL+ rear lights
viewtopic.php?t=13426&fbclid=IwAR395lT9 ... BnD6dWstn0
RS theme info:
viewtopic.php?f=16&t=6676&fbclid=IwAR3I ... YrLAElnwsw
roylion15
Re: Avoir les feux arrière allumés en même temps que DRL
Post by roylion15 » Tue Jul 14, 2020 9:26 am
For 3.4 only the default theme is changed.
7D0-03-01 xxxx xXxx xxxx
Need change visual variant ford TIMELESS to ford CLASSIC set X to 0
https://docs.google.com/spreadsheets/d/ ... range=E189
Gustas_J
Re: Have the rear lights on at the same time as DRL
Post by Gustas_J » Tue Jul 14, 2020 1:48 pm
Thank you!
So just to be clear. Only need to change that one value for the RS theme to appear?
