Colored menu apim
CoD21
Vehicle: Ford Fiesta MK8
Colored menu apim
Post by CoD21 » Fri Jul 10, 2020 12:16 pm
hi,
i have seen that you can activate a colored menu in apim (pictures). on youtube i found out that it is "colored menu choices" in apim modul configuration. but when i connect my fiesta (my2018) with forscan, i dont have the option.
do you know the hex code for asbuild?
roylion15
Re: Colored menu apim
Post by roylion15 » Fri Jul 10, 2020 1:00 pm
Hello
you can use direct configuration :
Set the theme to ford "classic" instead of ford "timeless"
CoD21
Post by CoD21 » Fri Jul 10, 2020 1:24 pm
Thank you! The Option is super easy to find. Ist has The word „Design“ in it.
Do you Also know how to enable climate control on Sync 3?
CoD21
Post by CoD21 » Sat Jul 11, 2020 7:58 am
After i changed the design, the clock always "resets" after i restart the car.
I adjust the time to 9:57. after i restart the car, the clock shows 8:57. do you have any idea?
roylion15
Post by roylion15 » Sun Jul 12, 2020 11:52 am
Hello
there is a setting for the clock and timezone in the menus of sync 3.
For the climate icon,
for the fiesta mk8 . second block second digit.
7D0-01-02 xxxx xXxx xx if you have 4 set 0. climate icon will appear after a restart.
https://docs.google.com/spreadsheets/d/ ... e=A94:G102
CoD21
Post by CoD21 » Sun Jul 12, 2020 4:22 pm
Damn! Thank you! Does this Code work with every Sync 3 Car (2019 EcoSport)?
edit: how do i know whats the correct code for my car? like for the climate control icon. there 16 options. how do i know what option to choose?
roylion15
Post by roylion15 » Thu Jul 16, 2020 6:38 am
Give me the stock values you have on this line....
CoD21
Post by CoD21 » Fri Jul 17, 2020 5:21 pm
It says 7D0-01-02 -> 023E-0400-829C
roylion15
Post by roylion15 » Sun Jul 19, 2020 8:00 am
Hello
try the 0 value.
023E-0000-82xx
CoD21
Post by CoD21 » Sun Jul 19, 2020 7:17 pm
Thanks!
